Short shifter Question
Old Dec 9, 2003 | 12:36 AM
kevinss2001's Avatar
I just bought this off of ebay:
http://64.4.26.250/cgi-bin/linkrd?_l...aEOAB%3aMT%3a6
The guy does not have any installation instructions. It is just a shortened stick, does anybody have the instructions to install?
Old Dec 9, 2003 | 12:43 AM
zoomjrl's Avatar
dead link, should just be able to unscrew handle, slide off bag, unbolt old one, bolt old one, and but the bag and screw the handle back on
Old Dec 10, 2003 | 06:48 PM
It is a lot like this
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2448005288
but I would like to have some directions if anybody does have them so I really do not screw it up
Old Dec 10, 2003 | 09:15 PM
Rice Eater 316's Avatar
1. unscrew stock shift handle
2. open console and remove coin holder
3. remove two (2) 7mm bolts
4 lift up on console gently and free from remaining clips up front as well as unplug light in ashtray and the power outlet
5. remove two (2) bolts holding on stock stick and remove stock stick
6. install new short stick with the flat side to stock shifter. stick should be on the drivers side of the shifter. IF both sides are flat use the side that has a larger flat spot.
7. attach new bolts and tighten.
8. reassemble console in reverse
9. ENJOY
Old Dec 10, 2003 | 10:00 PM
thanks!
Old Dec 11, 2003 | 08:22 PM
Glad to help man
I've gotten tons of help from this board and it's nice to be able to contribute every so often
karpetcm
Feb 9, 2015 09:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
xmatt
Sep 16, 2002 02:37 PM
Decromin
Aug 18, 2002 10:11 AM
