shift kit q's
Old Dec 8, 2003 | 02:45 PM
udmwye96z's Avatar
shift kit q's
is a shift kit worth the money? How much time will it shave off of my 1/4 mile in my 96 z28?
Old Dec 8, 2003 | 10:35 PM
revtime's Avatar
I would say just for the fun factor a shift kit is well worth it.
You would probably see a gain but not that much from just a shift kit.
I put in 3.73s and a trans go shift kit at the same time and if felt like a completely different car.
Way more fun.
Old Dec 9, 2003 | 08:33 PM
Pro Built Automatics's Avatar
Sometimes the Trans-Go Shift kit can help with ET, but it mainly helps the transmission to live longer, by fixing slow shifts, addressing accumulation, increasing capacity, etc. (when installed correctly).
Old Dec 10, 2003 | 01:12 AM
90rocz's Avatar
B & M shift improver kit = $25- $30, and if you tranny has been a little slow between shifts, it could help your ET a little. As said it does help the trans live longer by raising certain pressures clamping a little harder. You can improve it more by adding a larger Corvette servo and tuning the governor.
I like those tire chirping shifts!...
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
