is a tc bad for a trans
Old Dec 6, 2003 | 02:36 PM
FLIPPINZ28's Avatar
i am getting a set of 3.73s and also want a tc about a 2500 stall is that hard on a stock trans and will i have to get it rebuilt soon if i go ahead and put it in there. thanks alot for any info also i have a ls1 with a 4l60e
Old Dec 6, 2003 | 06:04 PM
Antz97ZNJ's Avatar
the tranny will be hotter, but a cooler should solve that problem
Old Dec 7, 2003 | 04:34 AM
GoFast908Z's Avatar
Member
a trans cooler is a good idea, but with only a 2500 stall, your tranny should be fine. If you want better ETs, but don't want to go extreme, you might consider a 3000 stall convertor. 3500 would probably be too much if you are worried about tranny rebuilding, cuz then it would be more likely down the road.
Old Dec 7, 2003 | 11:17 AM
2000TA's Avatar
if your going to spend money on a TC I would go with the above 2800 - 3200 the tranny will be fine but like anything if you run it hard then expext to have problems. even if it were stock.
Old Dec 7, 2003 | 11:34 AM
GoFast908Z's Avatar
Member
Very true. It all about know HOW to race your car so that you don't overstress things and give yourself problems down the road.
Old Dec 7, 2003 | 05:29 PM
FLIPPINZ28's Avatar
so a 2800-3000 stall with my 3.73s sound good? what will i pick up in the 1/8
jackpawt883
May 21, 2015 12:34 AM
alphaauto
Jan 22, 2015 08:02 PM
Jan 5, 2015 07:14 PM
