Turbo Questions
Old Dec 3, 2003 | 02:23 PM
MEAN_SBC's Avatar
Turbo Questions
Just a thought in the very very back of my mind... What would have to be the engine requirements to turbo a 10:1 small block chevy???? Is this compression too high?? I was thinking it was a little high... Also, what type of fuel injection setup would be required??? Thanks.
Old Dec 3, 2003 | 06:10 PM
bad_turbo's Avatar
the compression is a little high. Most setups require 8.5:1 to 9:1 at the most. 10:1 will work if you check and re-check clearances and make sure everything is letter perfect and run only race fuel. My friend has a race car that has a big vorteck blower on it and he is running 10:1 compression with race fuel and 18 lbs of boost. But then again it is a race car.
Old Dec 4, 2003 | 01:32 AM
97WS6SCharged's Avatar
Just stick to 6-7 PSI and run good gas and you should be fine. You won't be able to turn up the boost too much with 10:1 compression.
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Newgmman
Feb 25, 2015 02:53 PM
blac94Z
Jan 22, 2015 11:19 PM
