what is the best tranny fluid, rear gear fluid???
I need to know, it is time to change the fluid in my high dollar tranny
and I want to put the most recomended fluid in there. I am going to go ahead and change my rear end fluid while I am at it. I have been using red line rear end fluid? what is the best???
Thanks,
Steve
and I want to put the most recomended fluid in there. I am going to go ahead and change my rear end fluid while I am at it. I have been using red line rear end fluid? what is the best???Thanks,
Steve
I run valvoline Maxxlife in the trans and mobil 1 gear lube in the back with GM limited slip additive.
I used mobil 1 in the trans and it hated it. Banged the rev limiter on the 2-3 shift. Once I put in the maxxlife I had no problem. Then the shifts got even better after the shiftkit.
Originally posted by 95Blackhawk
Hmm my shifting with Mobile 1 is much better than non-synthetic ATF. I would suggest a synthetic however.
