Ford Tempo cd install
Old Nov 15, 2003 | 11:27 AM
CrAkD X 95TA's Avatar
sup guys i got a tempo for $300 for a winter beater....im trying to install my old deck in it but the kid before me hacked off the warness i have all the wires grouped but i need a schematic telling me what color wire is what cause their not regular colors anyone know where i can find this???? i dont wanna buy a book for a POS winter car.
Old Nov 16, 2003 | 08:32 AM
bt96ss's Avatar
ford colors are green/yellow for 12v constant, yellow black for 12v switched, sometimes black or red for ground. speakers can be found by taking a 9volt battery and tesing spkr wires on the battery leads. it should make a scratch or pop sound when you hit the right wires. Once you have eliminated the powers and illumination. this method should work.
Old Nov 16, 2003 | 09:54 AM
Rogue Leader's Avatar
go here
www.installdr.com
Old Nov 16, 2003 | 10:50 AM
well theres no black or red for ground...the ground wire is fat black with a green stripe i think atleast......and when i hook up the deck (eclipse) i get absolutely nothing on the faceplate when i push the "open" button it opened up spit out the disk i left in when i uninstalled it and then didnt close back up and wont take anymore cds im kinda stumped here the eclipse worked perfect in my TA so i dont think its the deck has to be the wires.
Old Nov 16, 2003 | 11:21 PM
Javelin3o4's Avatar
try this link see if it helps..
http://paudio.tripod.com/ford-2.html
Old Nov 17, 2003 | 02:52 AM
x7x7's Avatar
what year?
Old Nov 17, 2003 | 12:06 PM
92
Old Nov 17, 2003 | 12:08 PM
yeah ive seen that already....see u cant just look up "ford wires" cause ford never set a specific set of wire colors....so every year is different...like the car is only a 92 but has some of the wires from the 98 and up...which makes no friggin sence....i got til friday to get this thing installed cause thats when i put it on the road and i cant go more then a day driving a damn tempo with not even a radio.
Old Nov 17, 2003 | 10:00 PM
Javelin3o4's Avatar
get a DMM, and first start testing for 12volt constant, then turn the key to the on position and look for your 12v ignition, once you have those you can look for your ground, or just make a new one. besure not to mistake the illumination as 12v or ground you will usually know you used illumination as a power or ground if your deck will turn off or on when the lights are turned on or off. then using like a 9volt battery start searching for speakers, take one wire and hold it to the + side and start touching other wires to the - side of the bat you will know you got one when you here it making a popping noise. then all you have to do is wire your harness up.
Also if you are not getting any power make sure to test your fuses under the dash and under the hood. Also i would go to a stereo shop or best buy and pickup a reverse harness so you can wire a factory plug back onto the main harness.
Old Nov 18, 2003 | 01:50 AM
x7x7's Avatar
http://www.the12volt.com/installbay/...63&type=Stereo
if that doesn't work just use a DMM and a AA battery. That's how I do it when there's no wiring info, doesn't take long.
Old Nov 18, 2003 | 07:26 AM
yeah i think i got the ground and constant cause whether the car is on or off if i push the eject button on it itll make a noise the first time i pushed it it spit the cd left in out but then the door never closed and now it just makes a noise whenever i push the button...car on nothing not a hint of anything on the face plate....on a dmm what should i look for for illumination?
Old Nov 20, 2003 | 07:58 PM
Javelin3o4's Avatar
illumination will usually show 12v. with headlights on and ground when its off, thats why its important to make sure you dont have illumination acting as a ground or power otherwise when you turn your lights on your deck will probably turn off.
Nov 18, 2023 07:21 PM
dfarr67
Apr 10, 2015 07:44 PM
cmyname1
Feb 19, 2015 08:38 PM
NewsBot
Dec 3, 2014 12:30 PM
