3rd Gen Single turbo
Old Nov 11, 2003 | 05:27 PM
1994B4C's Avatar
The car is 99% complete and all parts are new. This combo will make 1000HP and run high 8’s in the ¼. I wanted something fast and that was very streetable.
Chassis – 87 Camaro, Chassis Engineering ladder bars, Aldan Eagle coil-overs, 12-bolt, Moser 33-spline axles and spool, Wilwood disk brakes all around, Art Morrison tubular A-arm kit with coil-overs, Wilwood rack and pinion, mini-tub for 29.5x10.5W, 10-point cage, custom aluminum fuel cell that still uses the factory filler neck, factory dash and console, carpet interior, Cervini’s 4 inch cowl hood, drag lites.
Engine – 383 SB Chevy, internally balanced, New factory 4-bolt block with billet caps, ARP studs through out, eagle 4130 3.75 crank, Eagle H-beams w/ L-19 bolts, Ross dish pistons, Brodix Trac1’s – 300cfm, Victor Jr intake with EFI conversion, sheet metal elbow, Accufab 75mm TB, Cam Motion Hyd Roller, Comp Chromemoly lifters, pushrods, and rockers, moroso oil pan.
Turbo stuff – custom headers, Garrett HT3B turbo, Spearco air-to-air intercooler 26x11x4.5, 3 inch charge tubes, Turbonetics 42mm racegate, and Vortech BOV
Fuel System – Speed Pro Bank-to-Bank with WB/O2, 83lb seimans deka injectors, Weldon 2025 pump and regulator, All braided hoses for everything #10 feed, y-block, #8 return.
13,500 takes everything listed above. Located in Nashville, TN. .
To see pictures of the car go to http://home.comcast.net/~dwaynefleenor/index.htm
Email DwayneFleenor@comcast.net
Old Nov 12, 2003 | 09:30 AM
1994B4C's Avatar
ttt
Old Nov 13, 2003 | 04:58 PM
1994B4C's Avatar
ttt
Old Nov 14, 2003 | 04:52 PM
LT1Powered85Z's Avatar
Are you interested in selling the turbo stuff seperately from the rest of the set-up? I am interested in finding out about it from you.
I can't e-mail you here from work, so if you're willing/able, could you e-mail me at the address in my profile, with some information? eric_anderson99@hotmail.com
Thanks!
Eric
Old Nov 14, 2003 | 09:05 PM
1994B4C's Avatar
Hey Eric, you have mail
Old Nov 25, 2003 | 08:55 PM
1994B4C's Avatar
ttt
Old Dec 3, 2003 | 10:43 AM
1994B4C's Avatar
ttt
Old Dec 5, 2003 | 05:05 PM
1994B4C's Avatar
ttt
Old Jan 16, 2004 | 05:39 PM
1994B4C's Avatar
Someone make an offer, this car needs to go.
Old Jan 16, 2004 | 07:37 PM
KITTonSteroids's Avatar
props to that, that is one effin big turbo. im a huge third gen fan and i must say that is very clean. if you ever decide to do a writeup on that let us know.
Old Jan 29, 2004 | 10:00 PM
1994B4C's Avatar
Thanks Kitt. I just made a deal on the engine, turbo, and fuel system. So I won't be doing a write up =) Thanks
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
stars1010
Jul 15, 2002 03:51 AM
