Water temp gauge for 2001 Camaro SS
Old Nov 6, 2003 | 04:59 PM
Papajoe's Avatar
Purchased an Auto meter elect water temp gauge. Anyone know if I can get an accurate reading by splicing into the GM water temp sending unit or do I have to use the sending unit from Auto meter? If I have to use the sending unit from Auto meter, what is the best way to install?
Old Nov 6, 2003 | 05:36 PM
Ferocity02's Avatar
You can't tap into the stock sender, it will give you the inaccurate readings. What gauge did you get? They come with senders, mine did (Ultra-Lite CF). You can put the sender in the head by the #8 cylinder, which is damn near impossible, or, you can put it in the plug above the starter, this spot requires an adapter to fit, M16x1.5 I believe is the right size.
E-mail me if you need more help.
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
Camaro9534
Aug 27, 2002 11:38 PM
ExMustangOwner
Aug 18, 2002 06:03 AM
