t-top rattle fix?
Old Nov 6, 2003 | 07:49 AM
kkollwitz's Avatar
t-top rattle fix?
My 02 Z28 T-tops have started to rattle....has anyone had success fixing this?
Old Nov 6, 2003 | 08:18 AM
95GRNZ's Avatar
Thumbs up
SFC's usually help.
TS
Old Nov 6, 2003 | 08:23 AM
kkollwitz's Avatar
SFC
What's that?
Old Nov 6, 2003 | 09:46 AM
darrens99formul's Avatar
SFC = SubFrame Connectors.
They are a great suspension type mod. Welded ones work better then the slp bolt-ons. They cost about $130 I think plus install is extra of course. They are known to reduce or eliminate squeaks and rattles including the t-top rattle.
You can check around most muffler shops to find one that will weld them on for you.
Good Luck
Old Nov 6, 2003 | 09:55 AM
kkollwitz's Avatar
SFC
Oh I see now. I didn't make it clear, the t's are not rattling because of flex or looseness when in place, the rattle is inside the plastic housing which covers the lock assembly. I thought I would try to put some rubber gasketing between rattling parts inside it, but didn't see an obvious way to disassemble it.
Old Nov 6, 2003 | 11:35 AM
NEWBIE T/A's Avatar
Lightbulb T-Top Covers
If memory serves me correctly, the cover is held on by phillips screws on either end.
The handle is held on by a c-clip - pop it off, and the handle will come off easily.
I've tried "jury rigging" mine, and even bought new plastic inserts for the car frame - no luck.
I wind up bending the mounting tabs for a short term fix.
A few days ago, someone posted about putting that liquid foam that dries in, but I have yet to figure out where to put it - if indeed that is even the problem on my SS.
Britt
Old Nov 6, 2003 | 05:38 PM
Ferocity02's Avatar
SFC's will help with T-Top rattle only a little, wont completely fix it. You should still get them because they do a lot more as well.
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
HibachiZ28
Nov 6, 2015 12:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
WPHIG2
Aug 27, 2015 06:37 AM
