LS6 on a Camaro
Old Nov 3, 2003 | 01:16 AM
MarineInfantry's Avatar
LS6 on a Camaro
will a 405hp ls6 work on a 2002 z28? do i need to change anything for it to work? will ls1 aftermarket parts work on the ls6?
(headers, chip, pulleys, watever...)
thanks
Old Nov 3, 2003 | 01:57 AM
SStrokerAce's Avatar
You can drop in a 405hp LS6 into a F-Body. The tuning is a little different but nothing LS1 Edit can't handle.
If you are just looking for more power a set of ported LS1/LS6 or Truck heads and a small cam will make you more power than the LS6 does for about the same or less money.
Why do you want to know?
Bret
Old Nov 3, 2003 | 02:17 AM
i know a guy who can get me the engine, and many other parts, for around half the price. by the end of this month, ill be getting a 2002 z28 m6, and the ls6 engine will look sexy in it .
wats needed for the ls6 to work on the camaro. will ls1 aftermarket parts work with the ls6?
Old Nov 3, 2003 | 04:17 AM
http://corvetteactioncenter.com/specs/z06/
They externally are the same motor. Camshafts are different, Block and Head Castings are different.
All the parts on the two motors interchange.
Externally you can't tell the difference
Bret
Old Nov 3, 2003 | 07:35 AM
kmook's Avatar
Advanced Tech Moderator
General engine swap questions should be posted in Generation specific forums, moving to LS1 Tech.
Thanks.
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
hotrodyou1
Dec 20, 2014 10:05 PM
