Weiand/B&M 142/144 blowers???
Old Oct 24, 2003 | 09:16 PM
sleepybu's Avatar
whats the fastest you've gone with either of these blowers and what was your combo
thanks
Old Oct 24, 2003 | 11:42 PM
Turbocharged's Avatar
I ran the B&M 162 for lots of years and it ran 13 flat up here which is about 12 flat at sea level. Problem with the little blowers is that they just are too little. I had to have mine rebuilt about 4 times cause my pulley was so small to make more boost that the thing overrevved and would wipe out the teflon seals on the rotors. B&M was great and put new seals in several times for free. Car went 11.6 with NOS so if you want to go fast and run the little blower you ought to spray it some too.
Good Luck, Rick @ STS
www.ststurbo.com
Old Oct 24, 2003 | 11:58 PM
Well, sounds like you've got a pretty good setup for sure. Fix those traction problems and squeeze that thing. I used to have a 78 Monza with a turbocharged 350 running 20 psi boost. Fun car, blew up a lot of transmissions and rearends though. Poor little 10 bolts and those 5 speeds that I think only came behind the 4 and 6 cyls. Oh, the good old days!
Old Oct 25, 2003 | 12:30 AM
sleepybu's Avatar
Originally posted by Blown 75Vega
As of right now i'm only pushing 10 pounds of boost and still can go to over 20 and i'm smoking the slicks leaving the line at 1200 RPM's and run 10.24@133MPH. I like my little blower, plus i have NOS on top of the blower but havnt used it yet do to traction problems.
what size was the blower? What was the rest of the combo?
thanks
Old Oct 25, 2003 | 10:00 AM
engineermike's Avatar
I had:
B&M 144, 5 psi boost
TFS twisted wedge heads
9/1 compression 355
ZZ3 cam (208/221 - 112)
Edelbrock headers, 3" Exhaust, Flowmaster
700R4, 2500 converter
3.73 gear
3500 lb '89 Firebird
It ran 12.20's at 114 mph. I tried raising the boost to 7 psi, but it didn't gain any power, indicating that the blower was oversped.
Later, in the same car, with a 8.4/1 compression 355, AFR 210 heads, GM 847 cam (234/242 - 112), Victor Jr. intake, Vigilante 3200 converter, and SLP 1 3/4" headers and NO BLOWER, I ran 11.96 at 114 mph. That just goes to show that a good head and cam set-up, even with low compression, can do better than a small blower.
Furthermore, I then switched to a 11/1 compression 383, same heads, cam, intake, etc., and ran 11.09 at 122.5 mph with NO BLOWER.
Old Oct 25, 2003 | 01:13 PM
By the way, I measured the boost temperature of mine at 7 psi and it was over 200 degrees F during a 40 degree night. That puts its adiabatic efficiency at around a pathetic 38%. For comparison, a Vortech S-trim is around 70%.
Mike
Old Oct 25, 2003 | 02:00 PM
got_hp?'s Avatar
uhhh........whats the specs on that setup?!
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:39 PM
RUENUF
Mar 13, 2016 03:37 PM
bunker
Jan 30, 2016 08:09 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
