Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Custom brake lines...
Old Oct 15, 2003 | 09:01 AM
KGRESOCK's Avatar
Putting the finishing touches on the Areospace brake install and
want/need to have some custom lines made.
Anyone reccomend any places in the Wayne County area?
TIA
Kevin
Old Oct 15, 2003 | 10:48 AM
jzajac1's Avatar
Don't know of any in wayne county but "Inline Tube" in Fraser makes them "inlinetube.com".............................
Old Oct 15, 2003 | 04:16 PM
Birdie2000's Avatar
Is it possible to use -AN lines Kevin?
PS: you need the hard lines or the flex lines?
Old Oct 15, 2003 | 08:04 PM
KGRESOCK's Avatar
Jim,
Tried a couple local places to have a set made ...no luck.
I have some 24" 3AN lines I can use but 18"s
would work better, do you know where I can get 18" 3AN hoses
quick?
Kevin
Old Oct 15, 2003 | 08:08 PM
Birdie2000's Avatar
Kevin,
I know Scamchargers carries -AN line, not sure about -3 though. Do you need it already with fittings? Cause if not then you can cut your own length, and the fittings just screw right on.
edit: Also, while never having done it before, cutting it shouldn't be that hard if you can find something sharp enough with enough leverage. I guess the trick is to wrap the area in tape so that it doesn't unravel when cut.
Old Oct 15, 2003 | 08:35 PM
steve40's Avatar
Kevin, Check with Taner, I remember when we put his in he had some braided lines that where the perfect length. I don't know where he got them.
Old Oct 17, 2003 | 10:56 PM
charliediss's Avatar
Summit carries all that stuff, everything you need. Prices are not bad either.
Charlie
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
CARiD
Jan 14, 2015 04:00 AM
Collector Car
Jan 5, 2015 10:58 AM
