Tranny temp. gauge pinned over 250 Deg. !!!!!!
Old Oct 15, 2003 | 01:35 AM
94heritageZ's Avatar
I have a auto meter 2 1/16" tranny temp gauge on my a-pillar.
I have the sender in the pressure test port on the tranny. It
is an electrical gauge . My question (as well as brent frankers)
is the gauge pins itself over 250 Deg. within minutes of the car
running . When the gauge was pinned i took an Infra-red heat
gun and pointed it at the pan and it read 90 Deg
So i felt the pan and it was barely warm. WTF is going on ?
I own a 94 Z28 A4 . The same as brent but neither him or I
can figure this problem out. I tried grounding the sensor out
at the base of the sensor and still no luck. Whats really
fu(king weird is when i get on the throttle a lot the gauge
will jump erratically between 150-250 Degrees . When i let
off the throttle it goes back to over 250 Degrees. Any help
is appreciated. Thanks
Old Oct 15, 2003 | 12:26 PM
Z28SORR's Avatar
Sounds like an electrical problem or the wrong sending unit for the gauge. Check you electrical connections and wire gauge size.
Old Oct 15, 2003 | 03:27 PM
ChevyCamZ28's Avatar
That definately sounds like a grounding issue, are you sure that you are grounding the guage correctly? I believe that there was a seperate ground wire coming out of the guage.. is that going to a good ground?
Mike
Old Oct 16, 2003 | 01:13 AM
Yea it has a good ground.
Old Oct 17, 2003 | 11:24 PM
V-2 SQ Jes's Avatar
i have 2 autometer temp gauges, engine and trans, bought at the same time. the engine gauge read 125 as soon as i turn the key on. trans temp reads 80. 80 outside temps. the senders are the same. no bad grounds. i think its just a bad gauge.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Biggiebound
Apr 23, 2015 08:50 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
brentbrowning01
Dec 16, 2014 06:35 AM
