Please help, Zaino is streaking!
Old Oct 12, 2003 | 04:38 PM
Superfly97's Avatar
Angry Please help, Zaino is streaking!
My vette is black and I am a Zaino nut and have been using it for years. Never had a problem until now with a black car. When I am applying Z-5, for some reason when looking down directly in the hood, some areas are blacker than others. Like it is streaking some how when I apply it. I guess I just notice it now since this is my first black car. I am applying it evenly, but it still does it. It pretty much streaks in the way the I put it on. Does anybody have any idea what I am doing wrong?
Thanks,
Jon
Old Oct 12, 2003 | 06:23 PM
KevinSS's Avatar
Re: Please help, Zaino is streaking!
Thanks,
Jon
I dont know exactly what you are doing wrong, but it does take a little learning to deal with black paint (had a black car of some type in my life every day since 1987)
All you have to do is either mist the paint where the streaking is with plain water or Z-6 and it will buff out real even......
Could also be caused by your towels not agreeing with your finish and not remove quite all of the polish....
Old Oct 12, 2003 | 08:15 PM
Superfly97's Avatar
I am not really sure what is wrong either. Does Z-1 have anything to do with this? I did put it on before hand since the dealer buffed my car. The Z-6 helps a little but not much. Although, if I rub my finger firmly along the paint, it seems to come off a little. Maybe I am just not applying it evenly and not letting it dry long enough. who knows?
Thanks,
Jon
Old Oct 12, 2003 | 08:21 PM
KevinSS's Avatar
Thanks,
Jon
To avoid any streaks, make sure you put Z-1 on with a totally dry applicator, do not dampen it like you do when you apply Z-2 or Z-5 and rub the Z-1 into the paint until you can barely tell that there is any Z-1 on the surface. And Z-1 does not have to dry, as soon as you rubbed Z-1 into the surface, it is ready to put Z-2 or Z-5 on top of it....
Old Oct 12, 2003 | 09:20 PM
Slappy3243's Avatar
I too have a black car and it can sometimes be a pain but the results are worth it. Just make sure you apply the z-5 as thinly as you can and let it dry for at least an hour. It then comes off very easily with a cotton towel.
-Adam
Old Oct 13, 2003 | 12:45 PM
Superfly97's Avatar
Kevin, I have a feeling that this is due to the Z-1. I have put about 3 coats of z-5 since then. Would it even things out more if I went ahead and reapplied Z-1 on the car again. And you said rub this stuff in until you can't see it? I take it that this is still the back and forth motion right? If I do apply it again, will it effect the Z-5 too much for what I have already installed? I wouldn't think so.
Thanks,
Jon
Old Oct 13, 2003 | 01:52 PM
KevinSS's Avatar
Thanks,
Jon
Yes, it might even it out with another application of Z-1, Z-1 is actually applied in a circular over lapping manor.
You should rub the Z-1 completely into the surface, no coating should be visible, Z-1 should only slightly dull the surface, do not leave any streaks or bubbles of Z-1 standing on the finish.
All Zaino products are made to work together, a coat of Z-1 on top of what you have now will only make the bond stronger...
Old Oct 13, 2003 | 01:57 PM
Superfly97's Avatar
Thanks Kevin! I can't believe all these years I have been putting Z-1 on with the back and forth motion. I guess that I never noticed this as being a problem until I got a black car.
Thanks again!!!
Jon
Old Oct 14, 2003 | 07:49 AM
hcvone's Avatar
You can apply Z-1 in back and forth motion vs. circular, just make sure that you rub Z-1 in good and you will not get streaking, Z-1 needs to be worked in for best results.
Old Oct 14, 2003 | 07:52 AM
blkZ28Conv's Avatar
Lightbulb
On my black cars I also use a back-and forth application technique after applying the product first with a circular motion.
This insures complete coverage. Also you may consider getting some ZFX. This stuff really allows thin application and a 2nd or 3rd coat on the same day to insure a complete streakfree black finish. Because of ZFX the drying time is greatly decreased and the total time required to apply 2 coats is about equal to one coat plus drying without ZFX.
Old Oct 15, 2003 | 12:23 AM
detltu's Avatar
Hey I had the same problem with my SS (also black). It left streaks but I went ahead and used the Z-6 and they went away.
I hope that works for you
ChrisFrez
Mar 29, 2015 09:43 PM
nophix
Nov 30, 2014 10:26 PM
Dustin's97Z
Oct 4, 2001 04:12 PM
squirrels
Sep 24, 2001 02:31 PM
JSK333
Sep 22, 2001 07:50 PM
