Why no purge??
Old Oct 6, 2003 | 05:55 PM
Central PA Z's Avatar
Why no purge??
Have my NOS system all hooked up and opened the bottle. I checked my purge noid prior to this and I hear it clicking. Anyway.... after there is pressure in the line, the noid does not open. I drain the pressure and then it works again. If I click it open then open the bottle, it will stay open and purge untill I close the noid. Then it won't open again untill I release the pressure. I even tried a new noid and that does the same thing. Any ideas??
John
Old Oct 6, 2003 | 06:29 PM
Deadcarny's Avatar
what brand is the solenoid and what pressure are you at? if you are using a solenoid made by NOS they cannot take the same pressure as an NX....my NX purge will not open if it gets above 1200!
Old Oct 6, 2003 | 06:47 PM
Bottle pressure was only at 900. I am using all NOS brand noids. I am not sure of the PN on the purge noid, but when that one wouldn't work, I switched that one for my NOS N2O noid, PN 16020, and that one did the same thing.
John
Old Oct 6, 2003 | 07:11 PM
Mikie's Avatar
Ive had that problem with faulty solenoids. My solenoids would open below 700 psi , but once you go above that they wouldnt open. If you are using NOS and the solenoid is new , then you just need to contact Holley-nos and tell them they sent you a new faulty solenoid.
Trust me.
Mike
ps...the only other thing I can remotely think of is that you need to check your ground wire.
Old Oct 6, 2003 | 09:36 PM
SmokinZtires94's Avatar
First check that it is wired ok and the ground is good. You might have a faulty noid cause my purge works fine even when bottle press is over 1000. Get a new noid and ever thing should be fine. I would try to rebuild the noid either, just get a new one. hope everything works out for ya !!
Quickss96
Jan 29, 2016 05:56 PM
350350
14
Aug 11, 2015 12:03 PM
Strick
May 26, 2015 11:41 AM
NXz28
N2O Tech
Jul 16, 2003 07:31 PM
Hawk
N2O Tech
Jan 13, 2003 07:34 PM
