How do I install the fpss? NX kit
Old Sep 10, 2002 | 03:47 PM
Randy Molkentine's Avatar
Question How do I install the fpss? NX kit
I bought a NOS fpss and it has no tee fitting or anything just a 1/8npt port. What kind of tee do I need and do I need another line? Thanks, Randy
Old Sep 13, 2002 | 11:10 AM
Post
Anyone?
Old Sep 13, 2002 | 01:30 PM
speedmiser's Avatar
Post
There's lots of ways you can do it. The easiest would probalbly be to go to the local hardware store and buy a brass female 1/8" T and a closed 1/8" brass male nipple (unless you can find a T with only 1 male end.) Take the compression/hose fitting that's currently in the fuel solenoid out (the one that connects to the fuel supply). Take this fitting and screw it into one side of the T. Screw the nipple in the other side of the T. Take the nipple (which is now connected to the T), and screw it into the fuel solenoid. Screw the FPSS into the branch end of the T.
This is assuming your running the small nos type solenoids with an 1/8"npt female opening
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
http://www.houston-f-body.org/forums...car&u=48&v=247
[This message has been edited by speedmiser (edited September 13, 2002).]
Old Sep 13, 2002 | 02:12 PM
Post
They are the solenoids that come with the NX kit.
Old Sep 14, 2002 | 02:41 PM
speedmiser's Avatar
Thumbs up
<font face="Verdana, Arial" size="2">Originally posted by Randy Molkentine:
They are the solenoids that come with the NX kit.</font>
I'm not sure what size the NX solenoid port is. If it's not 1/8", then get a T that has the same size openings that the solenoid has and follow the same directions I gave you above, with one execption. Get a reducing bushing to screw into the branch end of the T, so that your FPSS will still fit.
If you have any doubts about these instructions, simply print this thread out and take it to the hardware store along with your solenoid, inlet fitting, and fpss. The hardware store employees should be able to hook you up. It's just basic plumbing afterall.
And if you dont already have any, get some telfon paste while your there, for each threaded connection.
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
Don 97 SS
Jul 11, 2005 08:50 AM
