75 or 125 Zex shot on a stock 93 LT1
Old Sep 10, 2002 | 02:10 AM
JH3204's Avatar
Post 75 or 125 Zex shot on a stock 93 LT1
I'm looking to buy a Zex nitrous kit for my 93 z28. it has 50,000 miles on motor, and the only mods to the engine are crane 1.6:1 roller rockers. other than that i have a hypertech chip, 160stat, hollowed cats, hooker catback and cai. should I run a 75 shot or 125 shot? My 1/8 mile best is 8.85@80.48. what times will i be looking at after install?
Old Sep 10, 2002 | 08:30 PM
justahoe's Avatar
Red face
I would go with the Nx kit instead, safer kit because it is a wet kit where Zex is a dry kit, about the same price if you shop around, Nx is rear wheel hp, not fwhp, just running a 75 shot knocked about a second off my 1/4 mile time.
95Z basics, 4:10's, Nx kit
Old Sep 11, 2002 | 03:03 PM
onebad97z's Avatar
Post
I like the Zex kit. I have had both and i prefered the Zex. It is way easier to hook up and it actually tricks the motor and adds more fuel at the same time. I had the 125 on my stock motor so you should be just fine with it.
Old Sep 11, 2002 | 07:19 PM
donot_4get's Avatar
Post
I'm going to ask this questio again...lol
How can a 1993 use a dry shoot if we don't have a MAFs?
I know that everybody spray before the MAFs on the dry shoot on lt1s, but we have speed density... what's up with that?
1993 Z-28
13.7s@99.97mph (CAIs and Cut-out)
Hooker Lts => Custom "Y" pipe with two cats, e-mail for pics, (It's possible! )
Lt-4 Hot Cam, 1.6rr, and springs (Crane Cam lifters)
new times coming soon!
http://www.tereschubert.com/camaro
(site needs update for cam and headers)
Old Sep 12, 2002 | 11:12 AM
n2oTransAmLT1's Avatar
Post
Man, our cars dont use the maf to calibrate nitrous/fuel mix like the LS1s do.
It is sprayed after the MAF if you dont have one, then thats all the better. Fuel is added via nitrous pressure on the FPR which in turn causes the stock fuel injectors to add more fuel. I too have the kit and love it. Super easy to install, came with an inline fuel pump and has run perfect since day one. You can probally run 125 with no major problems. I am. The only problems I had was I burned plugs once due to not using the correct heat range. Get some TR6s. Dont use Zex Hyperformance plug, I did and they dont work right in our cars. I was having detonation problems under normal driving conditions. My current problem is that I blew my cats out..both of them. I am currently replacing with Mac 93-95 headers with y-pipe and offroad pipe. My engine has never been harmed in any way...yet! Ive been running the Zex kit for about 9 months.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit with all the extras, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, NGK TR6 plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
UPDATE(8-02-02) Moser 12 bolt is here.
oldschool
Feb 9, 2016 09:21 PM
jb4xx
Feb 2, 2015 10:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
