adding nos to stock lt1
Old Sep 6, 2002 | 12:28 AM
bigkidd's Avatar
Post adding nos to stock lt1
having read alot of the post here i would like to confirm what i have gotten from it.
i should be able to add nos 100 to 150 shot to my stock lt1 z28 with no problems.providing i install the right safety devices and switches.i realize anything can happen but for the most part i shouldnt worry to much about messing my engine up or doing a rebuild\build up first like i would have too,to add turbo or supercharger.i do plan to add headers,exhaust and head work later but for now its stock with only minor mods (ram air cai,air foil.)106k on car now.running low 14s(bad reaction times)
Old Sep 6, 2002 | 06:14 AM
RacinLT1's Avatar
Post
Unless you change fuel pumps,you might wanna stay away from the 150 shot with a pump as old as yours.
I run a 150 on a stock LT1,new fuel pump,and am having fairly good results.
btw,reaction times have no affect on et.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Old Sep 6, 2002 | 09:25 AM
bigkidd's Avatar
Post
thanks.
yea i kinda forgot about the reaction time thing.
a new pump it is then...
thanks again...
Old Sep 6, 2002 | 09:56 AM
JCfromTR's Avatar
Post
Does anyone know if you need to upgrade the fuel pump for a dry 75-100 shot?
Old Sep 6, 2002 | 10:39 AM
Dave 96TA's Avatar
Post
JC - I would suggest you seriously consider a new pump and maybe injectors since the 'dry' method pushes the pump and injectors much harder than stock or a 'wet' kit.
Dave
White 96 Trans Am M6
Hooker LTs, custom 3" y-pipe, MAF descreen, Ported MAF ends, LT4 KM, 1LE elbow, front Powerslots, shortened Pro 5.0, BMR STB, PHR & SFCs, SLP Loudmouth, Clutch/PP & CAI, !CAGS, NGK TR55s, Taylor wires, Konig Monsoons, MAC overdrive and March underdrive pulleys, ES poly tranny mount, Harlan shift light
*No times on Nittos yet...
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
