? about carb and N20
Old Sep 3, 2002 | 07:03 PM
super83Z's Avatar
Post ? about carb and N20
I have a NX TPI/LT1/LS1 kit. I have zero room for a plate kit with my intake and hood. My question is can I use this kit that I have because it is a fogger kit? can I just screw it into my air cleaner and let it spray right down the carb? Or do I have to buy a carb fogger kit? thanks
Shawn
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983 Z28- 406ci
LT1 intake
AFR 195's
1995 Z28- 350ci
A4, leather, T-tops bone stock for now.
250 RWHP 300 RWT
14.0 @ 99 MPH on a 2.2 60'
Old Sep 4, 2002 | 09:23 PM
super83Z's Avatar
Post
no one here has a carb and N20?
Old Sep 4, 2002 | 09:33 PM
justahoe's Avatar
Lightbulb
I suggest talking to the folks at NX. They have a excellent tech. line.
Old Sep 4, 2002 | 09:51 PM
pink68's Avatar
Post
Super, I would imagine the biggest problem is that the N2O jetting in that system you have is based on a much higher fuel pressure than you would have with a carb.
Old Sep 4, 2002 | 11:02 PM
AutoRoc's Avatar
Exclamation
I am doing the same thing. I converted a 305 TPI to a carb setup with a 600 Holley and Performer Intake. I have an NX LT1 wet kit that I used with great success on the TPI intake(75 shot) and now I need to convert to a carb plate with biger fuel jets. Call or email Nitrous Express. I need to do the same actually ASAP!
And I hear ya about hood clearance!!! I am using a stock TBI air cleaner actually with a K&N and homemade ram air(4") Goodluck!!
Denny Villemure
1989 Camaro IROC-Z Convertible, 305 TPI, 2.73 Gear, Flowmaster 2 chamber. 15.60 on motor, 14.20 on a 75 shot from NX. Woo hoo!
www.denny.cz28.com
Old Sep 4, 2002 | 11:17 PM
CustomN2O's Avatar
Post
Well, I will chime in here and try to help, although it will probably get deleted cause Im not a paying advertiser, but here it goes.....Dont use the nozzle for the carb application. Buy a conversion kit, which will probably run you about 160 bucks(depending on where you go). I would recomend the hitman conversion. It will come with the necessary jets and plate, to make the kit to fit the carb. The single nozzle wont really work with the carb. This plate will actually be adjustable up to 200hp. And it works great.
The conversion kit will let you use your solenoids, with the newly supplied plate, with the newly supplied jets.
[This message has been edited by CustomN2O (edited September 05, 2002).]
Old Sep 5, 2002 | 05:25 AM
super83Z's Avatar
Post
CustomN20 the only problem with that is I have NO hood clearance left.I have two little dimples in my air cleaner from contact with my hood blisters as it is.
1983 Z28- 406ci
LT1 intake
AFR 195's
1995 Z28- 350ci
250 RWHP 300 RWT
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
Cbr02
Aug 24, 2015 07:12 AM
bose
Jan 30, 2015 02:36 PM
