Freezing bottle before pumping?
Old Aug 20, 2002 | 10:36 PM
Chode89's Avatar
Post Freezing bottle before pumping?
Is there any advantage to freezing the bottle before filling with a filling station? I could see it lowering the pressure but don't see the advantage when it is being forced in. Thanks
Old Aug 21, 2002 | 07:40 AM
2094you's Avatar
Post
you can fit more in ,the bottle
when its too warm the pressure is too high
so you cant get that much in it
but if its cold you can get up 3lb more maybe even 4lbs when its cold like out of the freezer.
Old Aug 21, 2002 | 08:36 AM
red's Avatar
red
Post
I would be carefull adding extra pounds to a bottle. The bottles are designed to have a certain amount of space for N2O gas to form. The pressure from the gas is what forces the liquid N2O out of the bottle on use. If you reduce that area your bottle pressure will drop rapidly on the first shot effectivly giving you a "rich" condition and reduction in HP.
After you make a pass and use up those extra pounds the bottle condition should return to normal. But, you are not getting the full potential out of the extra pounds you put in there. Just a thought.
95Z M6
383
and a few other mods
Old Aug 21, 2002 | 03:08 PM
gb95zconv's Avatar
Post
I chill mine down in a cooler before getting it filled. It speeds the process up. You can safely put 11-12 pounds the bottle when chilled.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Aug 24, 2002 | 04:10 PM
99 1LE Hugger SS's Avatar
Post
Besides being able to squeeze an extra pound or 2 in the bottle, you will get a better fill by freezing the bottle(less air).
99 1LE Hugger Orange SS A4 #3906 1 of 8 made 7 M6's and my lonely A4
mods:HPP3, 160 thermo, flowmaster catback, Direct flo airlid, NX wet kit, Yank 3600E, Grott headers
Stock Suspension, No weight reductions
Best N/A ET: 12.59@106.44
Best NOS ET:10.83@124.8
1.75 60' on motor
1.51 60' on NOS
Dyno'd 306hp/347tq(motor)
462hp/533tq(NOS)
a427tripwr@aol.com
Old Aug 28, 2002 | 01:59 PM
TheZ's Avatar
Post
don't do it!!!!!
high 12's
Old Aug 29, 2002 | 10:32 PM
phoenix916's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by TheZ:
don't do it!!!!!
</font>
I just got nos and A place I called said to drop it off and pick it up the next day because they had to freeze it. Is this normal?
Old Aug 29, 2002 | 10:46 PM
MBonZ28's Avatar
Post
you dont have to freeze it but it should be colder then room temp. this will speed up the filling process and you will get more nitrous and less air. half hour in a freezer is plenty
Matt Bonventre
Motown Muscle Officer
www.motownmuscle.com
1997 Z28 Drop Top M6
STILL bolt ons
STILL stock long block
STILL stock suspension and gears
13.048@106.39
12.145@113.54 w/ 100 shot of the juice
Old Sep 1, 2002 | 05:32 PM
CustomN2O's Avatar
Post
Freezing a bottle is generally used when a "pump" is not being used to fill the bottle. When the bottle is chilled, it will accept the transfer of nitrous from a bottle(source) that is warmer, and of higher pressure. If you are using a nitrous pump, the only time it really would make a difference, is on a very hot day. Chilling the bottle will keep the pressure lower, so the pump doesnt have to work as hard. You should notice that the bottle is always warm right after it is filled. On an extremely hot day, like here in California, sometimes the bottle pressure gets so high while filling, that I have to release some pressure, and continue filling. I wouldnt worry about chilling the bottles on a regular basis though. It wont make any performance difference.
Old Sep 3, 2002 | 12:14 AM
Chode89's Avatar
Post
Thanks for all the replies. After filling a few bottles on a warm day it makes it much easier to have the small bottle chilled. Makes me wonder on some why I didn't just by a transfer line and siphon feed. Thanks guys.
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
1996LT1Z28
Apr 22, 2015 07:56 PM
charchri4
Apr 14, 2015 06:40 PM
alphaauto
Jan 23, 2015 07:42 AM
