The ole' plug question........
Old Aug 31, 2002 | 06:25 PM
1fastformula's Avatar
Thumbs up The ole' plug question........
awrighty...I have done ALOT of searchiung and was just needing a little input on these plugs. First off...I had the stock AC r45ts plugs gapped at .35..had some problems(detonation and foul out) and decided on the AC r42t. Does this sound like a smart move to make??? I would probably gap them at .35, but I have read that Nitrous=colder plug.
Any input will be great!!! Have not made purchase yet....that will be in the morning.
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/owne...php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula
Old Sep 1, 2002 | 05:26 PM
CustomN2O's Avatar
Post
Detonation isnt the result of the plug you are using, or at least shouldnt be. How much nitrous you spraying? If its less then 150, then realistically, the stock plug would be fine. If you want to change plugs, then just get a plug with a non extended tip. IF you run too cold of a plug, it will just foul really easily, and thats not going to do you any good. You really only need to go to a colder plug, when you start running alot of compression, and typically over 200 shot.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
Xiantyl
Jul 21, 2015 05:42 AM
Dark Zeiro
Jul 19, 2015 08:25 AM
