NOS 5176 QUESTIONS
Old Aug 17, 2002 | 07:16 PM
KENS96M6's Avatar
Post NOS 5176 QUESTIONS
Trying to finish up on my install. I have something that does not make sense to me. On th "T" fitting that goes between the fuel pressure regulator, the manifold vaccum line and the blue nitros regular, NOS instructions say to hook the line removed from the fuel pressure regulator to the center connector. This is the connector with the blue AN fitting and the jet inside. Then hook the other two fittings to the NOS regulator and the fuel pressure regulator(FPR). I would have thought the Jet would be in the line between the NOS regulator and the FPR. The way they show it, the jet is between the manifold port and ultimatly the FPR. I could use some insight. Thanks guys.
Old Aug 17, 2002 | 11:58 PM
OneFlyn95z28's Avatar
Lightbulb
the kit is right
the Jet controls how much pressure is put to the FPRR. if you put the jet to the FPR all the pressure would go to the manifold and not the FPR
Good luck!
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
Old Aug 18, 2002 | 10:10 AM
KENS96M6's Avatar
Post
Thanks for the reply. Just needed some reassurance.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
kandied91z
Aug 4, 2002 02:53 AM
FilledWithFurySS
Jul 26, 2002 02:00 PM
