New times with xtream 224/230&N20
Old Sep 20, 2003 | 02:16 PM
funina91ss's Avatar
all my mods are in the sig just click the link if you want to know what I have done. Now thats that is out of the way lets get to the problems I had first the charging sysytem is having trouble keeping up with the bottle heater and elec. wp/fans etc..So with the voltage being in the yellow I had to borrow a charger to just run the think. I would say I got it to about 12 volts. The run was on a 150 shot jetted rich 38 jet instead of the 35. Working on a way to get auto tap to read the obd2 pcm I have. So I am trying to play it safe. Other than that things were pretty good. I do think it could of hooked alittle better. but here it it..
1.605 60ft
4.591 330ft
6.666 594ft
7.134 8th ET
96.19 MPH
that shoudl be a 11.12 in the 1/4
10's in a few weeks
Oh and one more thing I just have to say Is first Thank GOD!Everything is working great and 2nd I have to let you guys know about Ion Salton ( MadZ28.com ) He has this thing screaming great now.. I think we can get it a little better too. So if your having trouble with your obd1 car not shifting email him hard to beat the price and service.
I also have to thank greg for the great Job of hosting my video's you can check out his site @http://www.screamandfly.com/home/
Now to the video's
short film dialup
Long film broadband
Old Sep 20, 2003 | 11:32 PM
dkeers's Avatar
Looks great. I have that cam coming in the mail right now from Combination. It's good to see it is working so well. I will have to talk to MadZ28.com about tuning.
Dustin
Old Sep 21, 2003 | 03:26 AM
funina91ss's Avatar
best NA pass was a 7.90 on street tires. with a 1.74 60ft @86mph
Ion would be a good choice for programing .. He got mine down real good on one try.. but I think I need to get it dynoed and see where I should have my shift points I had him put them at stock .Might have it shift at 6,300 if it pulls on the dyno past that.Good luck on yours..
L8R Sean
Old Sep 21, 2003 | 01:29 PM
N2OpwrdTA's Avatar
funina....are you running 1.6rr and that cam with stock valve covers? I went with 1.5rr cause I thought there might be clearance issues. If no, Im putting in some 1.6rr while the motor is still apart. Thanks.
Old Sep 21, 2003 | 03:00 PM
funina91ss's Avatar
I am running 1.6RR crane golds. no problems at all.
Old Sep 22, 2003 | 01:32 PM
T/A lt1's Avatar
What gear are you runnung now? I remember you talking about putting the 3.23's in it. I am hoping to go 10's with my new cam and TH350 setup with a 3.42 gear. I really like the N20+ high gear setup and it works good on the street too. Anyways nice run. Later
Old Sep 25, 2003 | 09:42 PM
funina91ss's Avatar
I am still running the 3.23 gear it is working out pretty good for me. Only thing on the Th-350 is the first gear isnt as low as the 4L60E but I think it will work just fine.
Old Sep 25, 2003 | 11:51 PM
madwolf's Avatar
Sean,
your firmness is stock, but it should be shifting around 6100 if not 6200.
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
BAD 97 WS-6
Sep 11, 2002 01:45 AM
super83Z
Jul 11, 2002 10:16 PM
