nitrous switches(where to put them) Post Pics
Old Jul 11, 2002 | 09:12 AM
stik6shift98's Avatar
Post nitrous switches(where to put them) Post Pics
i have no idea where i should put them
i was thinking about the ash tray but wnat to know if anyone has done this before...
i think ive seen it a while back but really didnt care bout it then.
my car is a 98 so its different than a 93-97 interior
thanxx in advance
Ran 13.398 with shi*ty stock bald tires havn't run with the nittos yet.
AOL SN: stik6shift98
1998 Camaro Z-28
Old Jul 11, 2002 | 09:46 AM
rskrause's Avatar
Moderator
Post
Ash tray ('95) can gets pics if you want 'em, but it's not hard to visualize.
Rich Krause
'95 Z-28 383 with Vortech, nitrous, etc.
"1FASTZ28"
Old Jul 11, 2002 | 01:37 PM
rpm4lalo's Avatar
Post
Since I have a double throw, single pole duckbill switch for my remote bottle opener, it is mounted in the ashtray. The nitrous arm switch is mounted to the left of my two fan switches where the gear pattern for the six speed use to be, I just dremeled the plastic to make the switches fit. I figured even if I accidently hit the arm switch, no nitrous would spray because the bottler opener would be closed anyway.
Lalo's 95 Mystic TA
"It will never be fast enough."
Old Jul 11, 2002 | 08:31 PM
JD30thZ28's Avatar
Cool
Here is a pic of my switch panel
http://groups.msn.com/_Secure/0MgB0c...witchPanel.jpg
Johnny Dahia
30th Anniversary Z28
Old Jul 11, 2002 | 09:37 PM
Dark Angel's Avatar
Post
I built a panel that replaces the ashtray. I have an arm toggle switch, heater switch and purge switch. I also have an LED that shows when I am in the RPM range of my window switch and a small toggle to switch banks on my A/F gauge. E-mail me if you want and I can send a pic.
2001 Z28, Black, leather and T's.
A few appearance, suspension and engine mods and she sniffs crack!
Old Jul 12, 2002 | 10:56 PM
kirschman's Avatar
Post
I put mine right under the cig lighter, that panel pops right out. Its two black heavy duty rocker switches, I used a dremel and also had to trim up the switches alittle. They fit perfectly!! My purge button is right beside my ashtray (sorry I'm a smoker) on the left of it. It was a VERY tight fit, only left about 1/4 inch around the switches for mounting purposes but it works.
If someone can tell me how to post pics I'll get some out I've got an el-cheapo camera but it will work.
96Z M6, 12 bolt Moser(3.73),NX wet kit(all the goodies),MSD 6AL,tayor spiro-pro,NGK tr-6,Star stage 2 kevlar,pcmforless programing, SLP CAI,!maf,LT4 NM,Flowmaster,Hurst roll control,BFG DR's,Pro 5.0,BMR DS loop...
13.52-103.8 mph
60ft. 1.99
no n2o times yet
Old Jul 14, 2002 | 02:08 AM
Post
thanks alot guys i wne wth the ashtray idea it looks awsome its a carbon fiber pice with two toggle switches thta light up and a push button switch and the best part is that the ashtray still closes
thanks
1998 Camaro Z-28
Old Jul 15, 2002 | 06:59 PM
volZfrk's Avatar
Post
Does anyone make a switch panel for the cd/tape storage area under the radio on a 94Z?
Old Jul 16, 2002 | 01:50 PM
n2oTransAmLT1's Avatar
Post
FWIW..Heres a pic of my buttons from left to right, purge, arm, heater, remoter opener.
http://www.geocities.com/lotus_tt/gaugesbuttons.jpg
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old Jul 16, 2002 | 01:53 PM
Post
Well, I dont know why the link doesnt work. You have to copy and paste it or retype it into the address bar for it to work.
Low 13's on motor.
Low 12's on bottle.
HectorM52
Jun 23, 2016 08:42 PM
95chwagon
Jan 13, 2015 09:19 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
omarECD
Aug 19, 2002 07:28 AM
Brent94Z
Mar 21, 2002 04:44 PM
