What fuel pressure should I run for 125 shot?
It's a nos wet plate kit. The car was a blower car with 5olb injectors and it locked up so I put the nos kit on it. It only has 27 degrees of timing in it to. What fuel pressure should I try to run for it?
As far as I know, most folks use stock fuel pressure when tuning up jets. So unless there's some other reason to set the pressure differently, that's what I'd use.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Dave
Stock fuel pressure should be fine....you deffenently need an upgraded intank pump though to supply the fuel for your app.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Greg
95 Z28 conv M6
NX 150 progressive,
I have a electric fuel pressure gauge in my car. Idle Im at about 38psi, normal driving 46psi, 75shot-54psi, 100shot-62psi, 125shot-71psi. I have a Zex kit, with an inline pump and stock 26lb injectors. Runs like a champ, now.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Low 13's on motor.
Low 12's on bottle.
<font face="Verdana, Arial" size="2">Originally posted by n2oTransAmLT1:
I have a electric fuel pressure gauge in my car. Idle Im at about 38psi, normal driving 46psi, 75shot-54psi, 100shot-62psi, 125shot-71psi. I have a Zex kit, with an inline pump and stock 26lb injectors. Runs like a champ, now.</font>
Dave
[This message has been edited by LPEdave (edited July 07, 2002).]
Alex Barnes
Jan 24, 2015 10:21 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
