Ran nitrous again today, but now car misfires
Anyhow I used nitrous for about 5 seconds today on my way home. When i went to leave later today the car felt like it was stumbling/misfireing. I took it too AutoZone for free "ses" check and it said that i was misfiring. Do you think that the plugs are the problem? I have new Accell 8.8 race wires so I dont think thats the problem. They are regular heat range Splitfire plugs. They have worked in the past. What plugs should I buy to replace the F****D up ones? Do you think its possible to have messed up the optijunk? Any help would be great.
`96 TransAm with 125hp Zex kit and tons of bolt ons.
Splitfires and N2O = not good....you may have detonated one of them....get you some NGK TR6 or some Autolite 104 . If you do find one or more detonated you may have bigger problems in those cylinders. Hope this isnt the case but you still need to change thoes plugs.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Greg
95 Z28 conv M6
NX 150 progressive,
Thanks for the response. I am hoping its not anything worse also. Wish me luck. Anyhow, since i have a zex kit, I ordered the Zex Hyperformance plugs. I think they are one cool looking plug (not like it matters). Check them out and tell me what you think. It was a little over $40 for them. http://www.zex.com/store/merchant.mv...egory_Code=HSP
You seem to have a fetish for poor plugs...
The NGK TR6 and Autolite 104 are proven to be excellent selections for the LT1 on juice. SplitFires are a POS for an N/A motor in a stripped down econ-box. I bet you burned the ground strap off several of them. Who knows what the ZEX plugs are? What heat range are they? How many steps colder than stock?
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Fred
Detailed Mod's List
I called Zex today and asked them what kind of plug is thier plug equal too. They said their plug heat range was the equivilent to an Autolite 103. I told them my application/setup and they said that I will not have any problem with these plugs burning up. He also stated that the quality of them is "far superior" to its competition. Hopefully he is right. They will be here frinday. Ill repost this weekend and let you know of theyre ****ty or not. Later
<font face="Verdana, Arial" size="2">Originally posted by n2oTransAmLT1:
Forgot to say they are pregapped at .032.
</font>
</font>
I suggest you do alot more reasearch on nitrous in LT1 apps before you spray again....you have allready made some basic mistakes and you dont want to make anymore. Right now your just shootn from the hip.
<font face="Verdana, Arial" size="2">Originally posted by gb95zconv:
</font>
</font>
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M short throw shifter, Walbro in-line fuel booster pump, Granatelli MAF, Airfoil, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD adj. timing, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
****..I forgot the reason i came on here a minute ago was to tell you that the plugs are in, and the car is running like a champ again. It does not idle different or anything. Also made 2 bottle runs on my street(prive owned dead end, only 15 houses on 1.5mile of road). Wow, it actually hits harder than before. I dont know if its just me or what. Anyway the plugs seem fine and the cars runs good. So far the plugs get an A+, at least for their first day. Later guys
Low 13's on motor.
Low 12's on bottle.
Low 13's on motor.
Low 12's on bottle.
