VE Master results
Old Sep 16, 2003 | 07:19 PM
[JFS]'s Avatar
VE Master results
I've been using VE Master to tune the car's low end. I started with a
stock-like bin, slightly modified for a CC305 cam (220/230). The
following links are screen shots of how the VE map is changing. Being a
speed density car the VE Master program, even after two sessions has made
a TON of improvement. The program is definately doing the job,
kudos to Joe Georger. The screen caps of changes might be interesting.
(355cid, 218/230 'Xtreme, AFR 190 heads, 8.5:1 CR, th400, t-trim)
Stock VE:
http://jon.shoberg.net/archive/image...-ve-master.gif
1st VE Master:
2nd VE Master:
http://jon.shoberg.net/archive/image...r-session2.gif
Old Sep 16, 2003 | 11:31 PM
Alvin@pcmforless.com's Avatar
Be careful..
I know VE master doesn't handle Idle and i'm fairly sure it doesn't handle decel either
Theres a program me and craig moates made like years ago at www.moates.net.. it definately does a better job but takes longer to use.
Its also a pain in the ****..
VEmaster is definately cool though
I remeber when i used to do those calcs with a pen and paper
Old Sep 20, 2003 | 10:41 PM
Fastbird93's Avatar
How well did VE master clean everything up in terms of drivability??
Rooster: If you're the same rooster I'm thinking of, do you use VE Master to help out??
Old Sep 21, 2003 | 01:03 AM
Hello,
Sorry don't check these boards often.
That program VEphd works good. Its just a bear to use.. And it won't work on my XP machine
Fastbird 93.. if your the same guy i think you are (car that wasn't lean but showed cause dyno guy error) than no don't use VEmaster or anything.. I'm actively tunig your car,
Old Sep 21, 2003 | 10:46 AM
Fastbird93's Avatar
Rooster, That would be me, and I wasn't planning on using it on that car. I tell ya though, I can't wait to get home and get the hesitation figured out and get to the track, and back to the dyno too!!!
G-BODYT56
Jan 14, 2022 11:14 PM
HAWG
Sep 25, 2015 11:41 AM
Daluchman1974
Sep 11, 2015 06:12 AM
