383 stoker for an 86 camaro
Old Sep 10, 2003 | 09:34 PM
mechanicZ's Avatar
i am finally able 2 rebuild and restore my car YA! and i want a 383 stoker but i have very little experince in stoker engines i know i have 2 have a 350 block with a 400 crank but what makes the stoker a stoker?
Old Sep 10, 2003 | 09:49 PM
"Stroker" means the stock cankshaft has been replace with one that has a longer stroke. That's about it.
Since you have a 86 model, this post would be best answered on 3rd Gen Tech. Moving it there.
Old Sep 10, 2003 | 09:55 PM
mechanicZ's Avatar
but if it had a longer stoke wouldn't it hit the heads?
Old Sep 10, 2003 | 11:55 PM
raul.garcia's Avatar
Stroker
Yes, if the stroke is longer it will hit the heads, or valves when they open. The rod and pistons will need to be changed so that it all fits in the cylinder.
Example:
My cylinder length is 9" (deck height) my crank is a Scat 350sbc 3.75" vs. stock 3.48", my rods are 6" vs. stock 5.7", and my piston compression height is 1.125" vs. stock ~1.56"
You take half the stroke, add the rod length & piston height, and it should total to the deck height.
3.75"/2= 1.875"
1.875"+6.00"+1.125"=9"
spearous
Jan 12, 2015 11:03 AM
deadmanrunning
Jan 3, 2015 01:12 PM
Collector Car
Dec 17, 2014 01:12 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
