Easiest way to check which gear ratio i have?
Old Sep 10, 2003 | 10:45 AM
foff667's Avatar
My rpo says GU2 but with the rpms im tuning and how well my car did at the track the other day says i have 3.23's...my thinking is if i pop the rear cover and it has the reluctor ring ive got 3.23's or higher...if it doesnt have the ring ive got 2.73's is this the easiest most accurate way to do this?
thanks
Bill
Old Sep 10, 2003 | 04:27 PM
GREGG 97Z's Avatar
If you have the 1st gear selection on the shifter it is 3:23, if not 2:73's. Thats assuming the rear is stock.
Old Sep 10, 2003 | 05:31 PM
If you are going to pull the cover off, GM gears will be marked (or just count the teeth). You can also count the number of rotations of the driveshaft to one rotation of the rear wheel without pulling the rear cover off.
Old Sep 10, 2003 | 07:14 PM
foff667's Avatar
ok which i do but i have the gu2 code so what does that say? lol
lata
Bill
Old Sep 10, 2003 | 08:19 PM
ATMINF's Avatar
Another easy way that gives a good idea is to put the trans in drive not OD, then drive up to 70mph and if the rpms are around 2700 you have 2.73's- 3200 3.23's- 3700 3.73's. This is a rough estimate but it will givve you a idea. Good luck.
Old Sep 13, 2003 | 09:59 AM
FIREHAWK_21's Avatar
Look at this.
http://www.f-body.org/gears/
Old Sep 13, 2003 | 11:44 AM
V-2 SQ Jes's Avatar
traitor lol, jk dude
Old Sep 15, 2003 | 11:03 PM
coogsLS1's Avatar
same apply to a m6?
Old Sep 16, 2003 | 01:55 PM
coogsLS1's Avatar
TTT
Old Sep 16, 2003 | 03:43 PM
GREGG 97Z's Avatar
Originally posted by coogsLS1
same apply to a m6?
No. If your gears are still stock though you have 3:42's. All 94-02 M6 cars came with 3:42's.
Old Sep 16, 2003 | 11:04 PM
coogsLS1's Avatar
how would I find out if they are modded and I dont know it?
Old Sep 17, 2003 | 09:51 AM
GREGG 97Z's Avatar
What are your rpms in 6th gear at 70mph? When I had 3:42's it was around 1900-2000 rpms if I remember right. Now with 4:10's it's around 2200-2300. Try that and see what it's closest too, it should give you a pretty good idea.
Old Sep 17, 2003 | 08:54 PM
mr_camaro96z28's Avatar
The only way to know for sure what gears you have is to pull the cover off and count the number of teeth. Count the number of teeth on the ring and then count the number of teeth on the pinion and divide the number on the ring by the number on the pinion. For example, i have 37 teeth on my ring and 9 teeth on my pinion that comes out to equal 4.11.
Drew
Old Sep 17, 2003 | 11:31 PM
coogsLS1's Avatar
thanks for the basic guidelines, greg.
how much is involved in pulling the cover off?
Old Sep 18, 2003 | 06:40 AM
foff667's Avatar
a socket set, a gasket scraper, an oil pan and new gear oil and posi additive.
lata
Bill
Jul 4, 2005 05:00 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
