A4 shift point different than programmed?
I use LT1-Edit on my 95Z A4 w/ Trans-Go shift kit. The stock WOT shift point for 1-2 is 36mph. When I look at my logs it shows the trans going into 2nd gear at 41mph. Does anyone else notice this? Is this just the time it takes the trans to actually make the shift?
Yep, both the speed and the RPM thresholds have to be met before the transmission will begin to shift, and of course you'll exceed both of those parameters by the time the shift actually occurs.
carguyshu
Jan 22, 2017 11:19 AM
