clutch won't disengage
Old Sep 7, 2003 | 01:29 PM
NeoSNK's Avatar
When you push the clutch in and try to start it it jerks the truck. We have bled it and the cylinder is moving but not quite enough I guess. This is a 5 speed in an 88 chevy truck. Could it be the resevoir not making enough pressure or could it be the cylinder?
Old Sep 7, 2003 | 05:07 PM
Rodrigues's Avatar
If it is truly bled properly i would assume the cylinder.
Old Sep 7, 2003 | 09:12 PM
rlax31's Avatar
i'd say unhook the clutch rod from the pedal and push it in manually as far down as you want, then try (a 2 person job ) That way you can make sure that the rod not going in far enough is the problem, but then again, i don't know anything about the trans in a 88 chevy truck
sherwinZ28
11
Aug 15, 2015 05:38 PM
Jlo
Jul 29, 2015 03:52 PM
ducttape1975
Jul 10, 2015 06:29 PM
mrwz28
Jul 8, 2015 09:11 PM
