trans flush now shift probs
Old Sep 6, 2003 | 04:19 PM
Brett68's Avatar
Just had the trans flushed and filter changed on my 95 TA at the Chevrolet dealer. Now the 1-2 shift at WOT went to 6000 rpm and I had to get off the throttle for it to shift. I have 108k miles on it and haven't had any prior trans problems. Is it possible their machine was running to high pressure and damaged a solenoid?
Under "normal" acceleration the trans shifts fine.
Old Sep 6, 2003 | 11:33 PM
Fatdog's Avatar
Cool
Mine shifts at about 5800.I think that 6000 means your engine is in peak performance.Sounds good to me,but I dunno.Anybody else?
Old Sep 7, 2003 | 10:23 AM
Terran2k's Avatar
isnt the rev limiter ~5800 rpm? you shouldnt even be able to get to 6000 without hitting the rev limiter 1st...well unless you had it removed. maybe your tach is just off by a few for whatever reason? i know mine reads like 750rpm at the tach at idle, but when i use autotap, the computer see 550rpm.
Old Sep 7, 2003 | 10:39 PM
94 TA TT2S's Avatar
I had the same problem but mine was from 2-3 and sometimes 1-2 ......Been told it was time for rebuild....But like you said I prior problems....From what I have read on here...It can be the tranny is on its way south......The fresh fluid allows the clutches to slip much more than the old fluid ( which had particles that helped it grab) ......Several other thinks it could be.....Can't think of off hand....Hope you figure something out....
Old Sep 7, 2003 | 11:37 PM
Cmr0z28's Avatar
this is correct.....the bands inside the tranny rely on all the crap that's built up over the years for grip......once you flush and change the fluid, they cant grip anymore, and now your tranny is slipping. time for a rebuild.
Old Sep 8, 2003 | 01:14 AM
chasmanz28's Avatar
thats why alot of guys with high mileage wont even changed the fluid because of this very problem
Old Sep 8, 2003 | 01:16 AM
94 TA TT2S's Avatar
I still have an issue at hand....If I have it rebuilt I am still gonna face the OBD-1 High stall stuff after I do.....What to do What to do????
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
Brake_L8
Jan 20, 2015 09:44 AM
blac94Z
Jan 12, 2015 05:44 PM
