Hich Pitched Chirp
Old Sep 5, 2003 | 12:55 PM
petegz28's Avatar
Hich Pitched Chirp
I am hearing a high pitched chirp after I shut off the engine. Sounds like something spinning or escaping. Any ideas???
Old Sep 5, 2003 | 11:35 PM
Lan01z's Avatar
check the flux capacitor
Do you have a K&N with the breather attachment? mine makes noise out of that sometimes.
Old Sep 5, 2003 | 11:39 PM
Lan01z's Avatar
I'd probably check the serp belt too. Check out the tensioner to see if its all tight.
Old Sep 6, 2003 | 02:37 PM
petegz28's Avatar
This is after the car has shut off. So the belt it isn't spinning. I am wondering what parts might still be spinning down after you kill the engine.
Old Sep 7, 2003 | 01:21 AM
AL SS590 M6's Avatar
Moderator
Try turning your heater off before shutting the car down. It might be the blower fan for the HVAC.
Old Sep 7, 2003 | 11:47 AM
pg318's Avatar
If it's a whirring, it might be the cooling fans runnings on. If it's more of a hissing, that only occurs when the AC has been running, it's just the AC high pressure side bleeding down - normal.
Greg88
Aug 24, 2015 07:59 AM
pennys58
Apr 25, 2003 02:31 PM
96TransamConvt
Apr 24, 2003 11:28 PM
Decibles
Sep 18, 2002 12:13 AM
