Disc Brakes
Old Aug 13, 2002 | 02:18 PM
RPerformance's Avatar
Question Disc Brakes
I am currently looking to upgrade my front brakes to discs and was wondering about the master cylinder, I know I need to get one to accomodate the discs, but do you know if it has to be set up for disc front-drum rear or can it just be a disc master cylinder? Thanks
Old Aug 13, 2002 | 06:36 PM
texlurch's Avatar
Post
You'll need one that matches your system, like disk/drum, or disk/disk. The drum brake masters have a check valve to keep the shoes out to the drum, the disk brakes don't. You can also use a slide hammer to pull the valve out of your existing master, but they usually don't have enough volume for the disk calipers.
Texlurch - 68 Camaro-LT1 w/Hot Cam, TT & TIC coming soon!
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Old Aug 14, 2002 | 11:03 AM
yzguy's Avatar
Post
I thought the check valve (also called residual pressure valve) was in the distribution block (or proportioning block) not the Master cylinder.
69 Camaro among other toys.
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
