SS Stock Exhaust
Old Sep 2, 2003 | 01:55 PM
2002 LS1SS's Avatar
SS Stock Exhaust
I am getting ready to buy a cat back system, however, my local muffler guy says the 02 SS (with stock SS exhaust...no SLP) has 3" pipes from the flange back. Do any if you technical guys know FOR SURE what size the stock pipes are? If they are 3", is there any reason to do a cat back, instead of a real nice muffler and some cool tips??? Please help...I was planning on doing this is the next two days.
Old Sep 2, 2003 | 02:06 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Smile
The stock SS pipe is 3", however I believe the "Y" pipe is still the flattend out POS, you might want to replace it with a 3" round pipe.
SteveC
Old Sep 2, 2003 | 02:24 PM
Lan01z's Avatar
Re: SS Stock Exhaust
-re: (with stock SS exhaust...no SLP) " -SLP makes that stock exhaust. It does have a 3" pipe from the flange back. Even the z28's have a 3" pipe back. The stock SS muffler has 2.5" tips out, so you'd probably just want a bigger output from your muffler. Get something with 3" out on both sides. The cat backs usually have smoother bends allowing for a slight increase in exhaust flow.
Old Sep 2, 2003 | 02:39 PM
Lan01z's Avatar
I hope I didn't sound harsh!!
The magnaflow would be a good choice
Old Sep 2, 2003 | 03:36 PM
SteveC's Avatar
Lan01z;
I respectfully disagree with your statement, stock Z28's have a 2 3/4" pipe going from flanges to muffler (y pipe is smaller), 2.5" out to tips.
SteveC
Old Sep 2, 2003 | 03:56 PM
Lan01z's Avatar
Originally posted by SteveC
Lan01z;
SteveC
Well, i'm confused then. I had my muffler shop try and install my friends ws6 muffler on my car. The muffler guy said that the inlet for the muffler was the same size and they even took a tape measure to it. Isn't that a 3"? Since the muffler was cut off so close, they couldn't weld it on the pipe. They told me that there wouldn't be any performance difference between the two anyway, so I bought a dynomax with 3" just because I couldnt put any other tips on the stock z28 muffler due to the lopsided off-center design So the stock ws6 and ss have a 2 and 3/4 pipe?
Old Sep 2, 2003 | 04:07 PM
transam8's Avatar
Correct.
-Mike
Old Sep 2, 2003 | 04:11 PM
Lan01z's Avatar
well, my bad, i thought they were 3"
Old Sep 2, 2003 | 04:19 PM
Lan01z's Avatar
So, basically the answer to this guys question would be to get a 3" cat-back. Since the stock ss is really 2 and 3/4.
Old Sep 2, 2003 | 04:36 PM
2002 LS1SS's Avatar
OK, so now i have two guys giving two diferent answers (to which they have finaly agreed that the stock pipes are 2 3/4"). Can anyone else with expierience ring in on what the stock sized pipes are in an 02 SS, not a Z28 (not that I doubt you, Lan01z or transam8, I just want to be absolutly sure before I make a $300 - $600 mistake).
Thanks again
Old Sep 2, 2003 | 04:56 PM
Lan01z's Avatar
More than likely you have the 3". I'd say your safest bet would be to call SLP and give them your vin number. They will be able to tell you right away what size inlet your muffler has. I've looked on their site and they sell both the replacement mufflers with 2 1/4 and a 3" replacement.
One thing I think is kind of odd is, the replacement y-pipe from slp features a 2 1/2" pipe.
http://www.slponline.com/view_produc...RTNUMBER=31035
Now wouldn't that be the bottleneck right there? Going from a 2 1/2 to 3", you really don't gain anything since you're restricted down to 2 1/2 at the y-pipe.
Old Sep 2, 2003 | 05:22 PM
9T8W66's Avatar
All factory exhaust I pipes are 2 3/4" regardless of what car they come on (Z, SS, Formula, T/A, and WS6.)Only the Firehawk comes with a standard 3" system (SLP Dual Dual) which is optional on the SS.
Old Sep 2, 2003 | 06:03 PM
SteveC's Avatar
Smile
9T8W66 is right on the money, I had my entire exhaust replaced on my 2001 Z28, from the rear 02 sensors back with 3" mandrel bent aluminized piping (I live in a warm dry climate) including the Y pipe, going into a Dynomax "Super Turbo muffler", with 2 3/4" pipe going to 2 "Megs" oval exhaust tips.
It is a little louder than the stock system, and it flows very well.
SteveC
Old Sep 2, 2003 | 07:34 PM
Lan01z's Avatar
SteveC
man, thats the same muffler i have!
Old Sep 3, 2003 | 07:42 AM
SteveC's Avatar
Thumbs up
Lan01z;
Good choice in mufflers, very high flowing, yet quiet enough to keep the local police off your tail.
An exhaust system does not have to be loud to be high flow and efficient (sp).
SteveC
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
spearous
Jan 12, 2015 11:03 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
