LTCC Users
Old Sep 1, 2003 | 08:48 PM
Fastbird93's Avatar
LTCC Users
Got a couple of questions:
If an opti is causing a low rpm/part throttle miss or stumble, would converting cure it, or would I still need a new opti??
Is the LTCC system compatible with a Digital 6+ or Accel 300+ ignition system, or would I need to get rid of either (have two cars with each system).
How reliable has it proven to be?
What was the total cost involved too??
Thx.
Old Sep 1, 2003 | 09:01 PM
InjectedSS's Avatar
HA yea right! no your gonna have to replace the opti neways and the LTCC is its own box! you cant use your aftermarket ignition box anymore and not to mention that the features on the LTCC SUCK!! i had it and HATED it... im now back to my opti and digital 7 box and couldnt like it more back to pullin tens again
Old Sep 1, 2003 | 10:53 PM
TonyJ's Avatar
I've seen very few LTCC owners who weren't happy. Do a search and you'll get all the info you need. It wouldn't hurt to try the LTCC first without removing the opti. It just might solve your problem. If it doesn't, replace your opti and you've got a pretty solid ignition for the future. Total cost for the LTCC could be:
$399 for the LTCC box
$50 for brackets for the coils
$100-300 for the 8 LS1 coils
I've got a source that sells the new coils for $20/each, so you're looking at about $560.
Old Apr 27, 2004 | 09:22 AM
mtxpert's Avatar
Can I sell/remove my ignition module when I change over to this?
Trying to sell my coil/module/Taylors as a package.
Let me know.
Mike
Old Apr 27, 2004 | 09:42 AM
IDOXLR8's Avatar
Let me know.
Mike
You will not need your ignition module or coil when you go with the LTCC box.
Old Apr 27, 2004 | 01:23 PM
TonyJ's Avatar
You might want to reconsider selling the wires. I reused my Taylors and they worked great. I mounted the LS1 coils under my cowl with some relocation brackets sold by Fischer Pontiac. Makes for a clean easy install. If you mount the coils on the valve covers, you can ditch the Taylors for shorter, more direct wires. Be sure and check with Turbo Bob about the best wires to use. Some seem to work better than others due to the shielding. The Taylors work fine on mine.
Old Apr 27, 2004 | 01:25 PM
mtxpert's Avatar
Since this is an Impala I'm going with fuel rail mounted coils.
I'll be buying a set of Taylor LS1 coil wires for this project.
Mike
Injuneer
Apr 25, 2022 06:22 PM
2QUIK6
Sep 17, 2016 02:31 PM
96SilverRam
Aug 9, 2015 04:15 PM
JCSWS6
Jul 19, 2015 06:47 PM
mrwz28
Jul 8, 2015 09:11 PM
