LT4 hp guess
LT4 hp guess
I just finished this 2 weeks ago and haven't had a chance ot get to a dyno, anyone wanna guess??
-LT4 heads
-LT4 intake
-LT4 extreme duty timing chain
-Comp Cams 'R' Series lifters
-Comp Cams xe 224/230 w/.536/.544 lift 112lsa
-Crane Gold 1.6 Self aligning roller rockers
-Crane dual coil .600 lift springs
-K&N CAI
-ZO6 MAF
-Trick Flow ceramic coated intake elbow
-52mm BBK throttle body
-160 thermostat
-Edelbrock shorty headers
-no catalytic converter
-flowmaster muffler
-New vented opti spark
-MSD 8.5mm superconutor wires
-AC Delco double platinum spark plugs
-New water pump
-LT4 knock module
-PCMforless
-LT4 heads
-LT4 intake
-K&N CAI
-ZO6 MAF
-160 thermostat
-flowmaster muffler
-New water pump
-LT4 knock module
-PCMforless
I've seen 4 LT1s with the LT4 conversion kit and hotcam dyno about 355rwhp with the M6 (tuned). With the XE 224/230 and 1.6s i'll step out on a limb here and say you'll get close to 365rwhp with a tune. If not 370 since there are quite a few members on here getting about 340rwhp with that cam on stock LT1 heads. The LT4 heads really are worth about 30rwhp over the stockers with a fatter torque curve in the higher rpms due to the larger ports.
