would a obd1 scanner work on a 95 if
Old Aug 31, 2003 | 10:25 PM
NeoSNK's Avatar
If I ran wires from the plug for the ground and diagnostic wire to the connections on the scanner? It seems like it would work to me even if I had to solder wires to the scanner. There only $30. Would it work? Has anyone tried it?
Old Aug 31, 2003 | 11:02 PM
NeoSNK's Avatar
I think I answered my own question. The cheap scanners don't have a screen and you need a screen to see the codes on these cars.
Old Aug 31, 2003 | 11:04 PM
madwolf's Avatar
Yes, you would need a "screen" one, plus one that would work with the OBDII connector. (Autozone ones won't work with it)
Old Aug 31, 2003 | 11:49 PM
If you make some little adapters like this, it will work fine and you can still use the 12 pin scanner plug on your older cars.
Old Sep 1, 2003 | 12:41 AM
No... it won't work fine. He's talking about a "$30 scanner".... that's the "short the ALDL pins" version of the Actron, and will not work at all on anything newer than a 1993.
Old Sep 1, 2003 | 08:18 AM
Of course, you are right. I sometimes don't read thoroughly late at night.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
Gtpguy
Jan 26, 2015 04:50 PM
