What exactly fails when the optispark gets wet?
Old Aug 31, 2003 | 04:24 PM
thewinner's Avatar
What fails on the optispark when it gets wet? Is it the high voltage side, or teh optical part?
I think that it would be the high voltage side right? Cause the optical part is just looking through a hole in a wheel, right?
Just trying to debate if its worth spending money to take the high voltage out of the opti or not
Old Aug 31, 2003 | 05:34 PM
I guess it depends on where the moisture gets in. I would bet most often it is the secondary ignition side that has problems. That's pretty much the rationale behind the LTCC conversion.
There are times when the moisture gets in through the electrical connector and that would lead it to the optical section, causing havoc with the electronics.
Old Aug 31, 2003 | 09:25 PM
thewinner's Avatar
thanks shoebox, anyone else know what failed on theirs due to water?
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
