descreened MAF?
Old Aug 26, 2003 | 10:40 PM
ea1's Avatar
ea1
descreened MAF?
I have seen long debates over the use of the stock f-body MAF without the screen. I have seen many people say that its not really a performance increase on an NA LT1.
My question is how does it effect a blown car. Its a 355 with a vortech s-trim at 12 lbs (hot cam also).
Thanks.
Old Aug 27, 2003 | 07:05 PM
RCF925's Avatar
I would also like to know the answer to that ?
Old Aug 27, 2003 | 07:49 PM
SMOKNZ's Avatar
I run the stock unmodified MAF. Works fine.
Bill
Old Aug 28, 2003 | 12:26 AM
ea1's Avatar
ea1
Bill
Do you run a blow-thru or a pull-thru MAF? I can understand that a blow-thru maf would be ok with the screen, but from what I have heard, any airflow restrictions on the intake side of the headunit is bad for power. Any thoughts on this?
Thanks.
Old Aug 31, 2003 | 02:16 AM
ea1's Avatar
ea1
Thanks.
Anybody have any more on this topic? Thanks.
Old Aug 31, 2003 | 04:13 AM
rskrause's Avatar
Moderator
Did an experiement this year when tuning my car. Put it in speed-density mode and ran it without anything on the intake side. It made 22psi of boost compared to 17psi with a custom fabricated intake "hard pipe". So, that illustrates what intake restriction can do. Made a big believer out of me. As a consequence, I will be switching my car to a "blow through" configuration next year.
Too bad I didn't think of it, because while we were fooling around it would have been very easy to test an MAF with and wothout a screen. But I run without one on the theory that it can't hurt and might help. Wish I had done that little experiment to put this to rest once and for all.
Rich Krause
Old Aug 31, 2003 | 09:47 PM
SMOKNZ's Avatar
Thanks.
I've run it both ways without any problems, other than the car not running after I blow off a part of the intake with the MAF on the suction side. I ran the Blow thru due to my turbo having a 4 " inlet. I just ran an elbow and a large 4" K&N filter off of that.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
