Need advice on rear end, 12 bolt? 10 bolt? HELP please
Old Aug 21, 2003 | 05:29 PM
Blue96z28's Avatar
As everyone can see from this post:
The bearings in my rear end are dead. There is also a pretty good chance that it took the gears with them.
http://web.camaross.com/forums/showt...9&goto=newpost
I need to find something new and I don't know what to do. It will cost me 500-600ish to rebuild my current setup with new lower gears and all new bearings including axle bearings. However I hear that the 10bolts suck anywayz, so what are my options, I don't want to buy anything used, so how much would a new 12 bolt with 3.42's cost? What all must be replaced?
Your help ASAP would be GREATLY appreciated, any ideas please, I can't really drive my car right now because of this.
Old Aug 21, 2003 | 05:35 PM
madhatter's Avatar
well 3 options
1) 12 bolt or 9" for about $2100.
2) Ford 8.8" can be made for under $500. I believe I heard of one guy doing it for under $200 I am not sure what all is involved to do this though.
3) stick with the 10 bolt and don't launch hard. Power and tourqe doesn't kill 10 bolts. Launches and people kill 10 bolts
Old Aug 21, 2003 | 05:41 PM
Blue96z28's Avatar
Well crap, I had no idea the 12 bolt would be that expensive....
I have an auto, without a stall.....is it likely that rebuilt 10bolt(If i fixed my current setup) would ever fail again with an auto?
What about with drag radials and a stall?
Old Aug 21, 2003 | 06:13 PM
FireAm94's Avatar
There are plenty of people on this board 7's (some low 7's in the 1/8) with auto's and 10 bolts running slicks. You will likely be good with the stock rear and a girdle etc...
Joe
Old Aug 21, 2003 | 06:18 PM
justahoe's Avatar
I'd say go w/ the 12 bolt or 9 in. If you look around you can proably pick one up for around 1800 on a gp sometimes. Or try to find one used, this is what I'm going to try do find.
Old Aug 21, 2003 | 11:12 PM
Blue96z28's Avatar
Anything over 500 is completely out of the question. Serious budget here. What is the girdle, just the back pan only stiffer? If that will help, I will definetely get one of those when I put it all back together.
Old Aug 22, 2003 | 12:18 AM
FireAm94's Avatar
Yeah...it replaces your rear cover....i'd go with a solid pinion spacer too...replaces the crush sleeve. Those would strenghthen it alot.
Joe
Old Aug 22, 2003 | 12:35 AM
Blue96z28's Avatar
how much do the spacers usually cost? what exactly is the spacer? and are the available at like jegs or summit or is it a specialty part?
Old Aug 22, 2003 | 09:45 AM
FireAm94's Avatar
I think it's $20 at thunderracing. It's supposed to keep the pinion from walking on the face of the ring gear.
Joe
Old Aug 22, 2003 | 10:26 AM
VINCELEE123's Avatar
10 bolt.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
