Smoke from left dash???
Old Aug 20, 2003 | 09:05 PM
drewstealth's Avatar
Twice when i started my car i have seen a very light amount of smoke coming from the left side of dash. Its all the way from where it meets the window. I don't have any codes or anything like that. The car seems to be running fine, and nothing out of the ordinary has happened. What do you think this can be?
Old Aug 20, 2003 | 10:43 PM
What can it be? Probably a problem that is going to jump up and bite you. If it is wiring, it would have a particular smell. It could be the the ignition switch or one of the connections to it. There is a lot of juice that goes through there and it is not uncommon for there to be heat damage to the switch and connector.
Old Aug 20, 2003 | 10:49 PM
pennys58's Avatar
Mine did the same thing, and it ended up being the heater coil blowing smoke into the car. It didn't smell, but it was smoke.
JOHN
Old Aug 20, 2003 | 10:51 PM
scoobysnax83's Avatar
if it doesn't smell, then its probably condensation from the A/C.... Is there a distinct smell?
Old Aug 21, 2003 | 02:06 AM
J's 82's Avatar
See above.. how humid is it in your area? Is the A/C on when it happens? My car blows clouds of condensation out of the vents when it is really humid out.. but that is VA..
Shoebox is also right.. what does your nosemeter tell you? Frying electronics is pretty noticeable..
Old Aug 21, 2003 | 11:41 AM
Yeah it doesn't smell at all. That is why i was unsure on what it could be. It is not really humid out here at all.
Knightscrapper
Feb 4, 2016 10:25 AM
hackman
Jun 7, 2015 10:31 PM
pimpinphil
May 30, 2015 04:20 PM
dylan1303
May 22, 2015 12:24 PM
siguy
Nov 27, 2014 10:07 AM
