PCV valve was now replaced and WHOAAAA
Old Aug 18, 2003 | 11:56 AM
ONELOUDKAR's Avatar
Thumbs up PCV valve was now replaced and WHOAAAA
Replaced PCV valve and man..... fixed every problem I had it seemed. I was throwing 2 codes, 44 and 64 before this was replaced or even looked at.. did everything i could and could not find what the problem was! Found out there was no PCV valve so I got the material, hooked that booger up and BAM,..... no codes and no idle problems..woooohoooo to me
just wanted to share that.... i would of never guessed it would of been something so simple!!
-Mike
Old Aug 18, 2003 | 12:15 PM
Seanndogg's Avatar
Must be nice to have fixed it that easy ... It is never that easy for me.
Old Aug 18, 2003 | 12:21 PM
bt95formula's Avatar
I replaced mine on both my firebird and toy tercel (work car) and the tercel's gas mileage went back up to about 37 from 31-32.
My formula stayed about the same though, 19-23
Old Aug 18, 2003 | 02:59 PM
ONELOUDKAR's Avatar
yea, this was the first time i have been lucky on my car, usually cost around 2k to get fixed.. so LUCKY me!
Old Aug 18, 2003 | 03:31 PM
Bobbys_97_Z28's Avatar
sweet
im glad that worked on y ours, but if you take your pcv out and it rattles and shakes, doesnt that mean that its good??
Old Aug 18, 2003 | 03:35 PM
Patman's Avatar
I don't have any problems, but I'm dying to change my PCV Valve since my car has 90k on it and I'm sure it's still the original one.
But I also have traction control, and the PCV is buried underneath this unit!
How on earth am I supposed to change the PCV on this car?
Old Aug 18, 2003 | 04:02 PM
Red96Lt1's Avatar
Re: sweet
Yes, if it rattles it's good. If it doesn't that means the little ball in there is stuck in it's position (open or closed).
Old Aug 18, 2003 | 04:42 PM
ONELOUDKAR's Avatar
all i had on mine was the rubber groument on the intake. i did not actual hose nor the PCV valve itself. i did have the connector in the front of the intake, but nothing going into it.. had a vacuum leak there.... patman, isnt your PCV right off the intake?
Old Aug 18, 2003 | 09:33 PM
Josh-'04 GTO's Avatar
Big fat vacuum leak will do it everytime! Makes the car run like crap...
Old Aug 19, 2003 | 10:32 AM
Patman's Avatar
Yes, but it's still under the TC unit. Unless I'm looking at the wrong thing.
Can anyone with traction control explain it better?
Old Aug 19, 2003 | 03:20 PM
Cam94Z28's Avatar
Funny,
I just went to change my PCV valve, and not only did pep boys have the wrong part listed, but the PCV i pulled out of my car had nothing inside it, I could see through both ends of it???
Is there a special Purolator part # for the correct PCV for the LT1? The one I bought was chrome instead of plastic, was straight up and down instead of L shaped, and had a smaller size fitting for the vacuum hose. The part I purchased was Purolator Part # PV895, it was listed for a 94 5.7L Camaro.
HectorM52
Jul 30, 2017 11:46 AM
grgguy
17
Feb 23, 2015 07:57 PM
Jazsun
Dec 29, 2014 12:14 PM
