Is this a "miss"?
Old Aug 17, 2003 | 09:26 PM
john96ws6's Avatar
Is this a "miss"?
I just got my car back from a well-known shop that put on headers and did a basic tune. While they had it tore apart they threw in some TR6 plugs for me. They didnt do wires, I was going to when I got home. They dynod it for me and the car put down 282rwhp and 325rwt. I thought that seemed kinda low. But they said my stock wires (70,000mi. ) were holding me back and I had a "little bit of a miss". So I drove it home and I noticed that at idle the rpms would bounce around sometimes. Is this what you call a miss? Or is it something different?
BTW I changed the wires this weekend and it ran fine for 20 miles and then my "miss" happened again.
Mods:
Hooker LTs and offroad y-pipe
GMMG exhaust
NGK plugs and MSD wires
3200 Vigilante
K&N filter with ram air
NX 100 shot
Other Misc. little stuff I forgot
Old Aug 17, 2003 | 11:46 PM
john96ws6's Avatar
C'mon guys. I bet a lot of you know. It seems like a simple question.
Old Aug 18, 2003 | 12:20 AM
delbuort's Avatar
I used to have an old 5.0 that did the same thing to me. It turned out just to be a vaccume tube. But, not long after I got my Z I had the little 'miss' problem and it turned out that my water pump had a leak in it and it was dripping into my opti. After I replaced the pump all my problems went away. Its kind of a long shot that its either of these but its always worth checking out.
Good luck,
Jason
Old Aug 18, 2003 | 12:31 AM
blueirocz-28's Avatar
I agree with the vacuum leak, also with the dripping water pump, check both things. Any rubber hose that has dryrot/cracks in it shold be replaced. Those hp numbers are kinda low...... no offense. It sounds like your car needs tuned, along with new wires, more than anything.
