What is going on with my spark plug wires?
Old Aug 17, 2003 | 12:04 AM
john96ws6's Avatar
I am putting the last plugs on the passenger side of the opti and for some reason the third one down keeps backing out. I put it all the way on and in about 5 minutes or less it backs its way out. All the other ones were fine and I put this one on the same way as the others. What am I doing wrong?
ERRRGGGHHH!!!! Two days of this and I am almost done!!!!
Old Aug 17, 2003 | 12:52 AM
AsianSensation's Avatar
Make sure you have enough slack on the wire and make sure you are not using di-electirc grease inside the opti boot. I had the same problem with a few backing out on the passenger side.
Old Aug 17, 2003 | 01:05 AM
john96ws6's Avatar
OH S**T. I thought you were supposed to use dielectric grease on them. Now I feel really stupid. But hey I'm only 18 and just beginning to learn about cars. Can I just wipe it off?
Old Aug 17, 2003 | 01:21 AM
I wiped as much as I can off the boot and it did the trick.
Old Aug 17, 2003 | 06:25 AM
scoobysnax83's Avatar
Well, the wire is supposed to click in. So yes and no with the dielectric grease. Only a small amount is needed. But you should put it in there. Helps to keep water out.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
