Where to go from here? Done all the basics
Old Aug 16, 2003 | 02:38 AM
tryme96Z's Avatar
Current Mods:
Port & Polished the MAF sensor
throttle body by-pass
!CAGS View Pic
SLP Cold Air Induction
Exhaust Cutout (after cats)
Eibach Proline Springs
T.P.I.S. Strut Tower Brace
BMR Lower Control Arms
Pro 5.0 Short Throw Shifter
Comp Cams 306 cam (230 / 244, .510 / .549 112 LSA)
LT4 Timing Chain
Port and Polished Heads
Mr. Gasket Head Gaskets (.026 thick)
Port and Polished Intake (and 58mm Throttle Body ready)
Comp Cams 1.6 Roller Rockers
Comp Cams Hardened Push Rods
Comp Cams "R" Series Hydraulic Roller Lifters
Crane Dual Valve Springs
Comp Cams Guide Plates
Hooker Long Tubes with JetHot 2000 coating
Taylor Pro Spiral 8mm wires
1LE Elbow
LT4 Knock Modual
Fuel Pressure Regulator (T.P.I.S. Top Hat Kit)
58mm Throttle Body
Hooker Catback
Boxed PanHard Rod
CSI Eletric Water Pump
MSD 6AL ignition box
Where should I go now for more power? Nitrous? Super/Turbo? Stronger rear end with maybe some 3.73s or 4.10s? Forged internals(probably go 383 or 396 while Im at it)? After having a Neon SRT holding fairly well at 130mph(read FAIRLY well, still didnt win ) its time for more mods.
Old Aug 16, 2003 | 03:48 AM
Compstall's Avatar
Get the rear end up to snuff, or just bust out the stroker $$ now and wait for the rear to break later on....
Old Aug 16, 2003 | 04:37 AM
texasTA's Avatar
I would find out exactly what is wrong with my car first and foremost. I hope the remark about a Neon SRT hanging at all was a totally sarcastic remark???
With that cam and FULL boltons you should ABSOLUTELY with-out-a-doubt WALK that four cylinder car. If it was just a joke, then I would consider possibly 4.10s or a nice shot of Nitrous. You can also do a nice 355 buildup with forged parts and spray till your hearts content.
Old Aug 16, 2003 | 11:07 AM
tryme96Z's Avatar
It was not a joke. And maybe I was pulling harder than I thought but I was busy looking straight. Your thoughts are exactly mine, I was VERY surprised he was holding as well as he did. It was too close for my likings. There is one thing missing really in my setup, I know you say I should be walking on him, but I only have DIY port and polished heads. My brother did them(he has experience machining), he always thought he did good but never had them flow benched. Sounds like I need to connect the laptop up and go log some runs and see if I can see anything afoot.
David Dempsey
Mar 12, 2016 12:42 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 10:09 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
