Autocross and Road Racing Technique There is more to life than a straight line
STB or swaybar??
Old Aug 15, 2003 | 02:03 PM
TMDZ28's Avatar
STB or swaybar??
i want to improve my handling performance, including taking corners at higher speed, and stuff. i want one mod that i can feel improve my car's handling....will strut bar do this or sway bar?? i've read that i might not feel the difference with stb? is this true??
Old Aug 15, 2003 | 04:40 PM
bruecksteve's Avatar
You might notice the STB AFTER you stiffen up your suspension first. Sway bar.
Old Aug 18, 2003 | 02:26 PM
snorkelface's Avatar
For changing the dynamics of the car, definitely do the sway bars first. Make sure you match the front to the rear and with your spring rates, though.
As for stiffening the chassis, get weld-in subframe connectors BEFORE you get a STB, as those are much more nreeded.
Old Aug 19, 2003 | 10:42 AM
TMDZ28's Avatar
will i feel the diff. is i use hotckis sway bar?? thanks for the opinions
Old Aug 19, 2003 | 10:46 AM
You will. But for the money, I'd go with the Suspension Techniques 35mm bar, you can get the 35mm bar for about $150. I wouldn't bother with the rear right now.
Old Aug 19, 2003 | 11:21 AM
Grover's Avatar
Who sells the 35mm bar?
Old Aug 19, 2003 | 11:22 AM
Go to www.stranoparts.com
Old Aug 19, 2003 | 01:46 PM
TMDZ28's Avatar
are you talking about the 1 3/8 inch??
Old Aug 19, 2003 | 01:51 PM
SWAY BARS
35mm (1.375”) front bar w/urethane bushings: $137.90
25mm (1”) rear bar w/urethane bushings: $130.00
Package (both bars): $255.00
Give Sam Jr. a call, he'll make sure you get the right one. It will be the best phone call you can make for your suspension.
Old Aug 19, 2003 | 06:37 PM
TMDZ28's Avatar
is that the phone number listed in the web dude?? i will call, and find out.....thanks man
Old Aug 19, 2003 | 07:48 PM
At the bottom of his opening page.....
football4life
Oct 4, 2015 07:48 AM
realistyc
Jul 28, 2015 07:32 PM
Jul 2, 2015 11:39 AM
97FormulaWS-6
Sep 11, 2002 11:57 AM
97FormulaWS-6
Aug 5, 2002 05:15 AM
