NEW DYNO NUMBERS with LT4 hot cam. check it out!!!!!!!
Old Aug 15, 2003 | 12:51 PM
TexasTechTA's Avatar
Finally i got soem decent numbers, the mods in ym sig. Also the tempo was about 100 degrees and also I am such a moron my AC was going. I drove the car 20 minutes and did not let it cool and only ran it once. here were the numbers
310 rwhp
323 rwtq
also the AF ratio stayed at about 11 to 1 the whole time up and down a little bit. But what do you guys think. If you remember I was running lean and the culprit was a bad maf. with more tuning what do yuo think is possible. Also tonight I am taking it to the track on slicks. IU have a stock converter though and 2.73 gears. Let me know what you think guys.
Old Aug 15, 2003 | 12:59 PM
Gripenfelter's Avatar
11:1?
I think thats a bit rich.
Who did the tuning for the cam?
Old Aug 15, 2003 | 01:06 PM
madwolf did my tuning,
also hey I got a bit of white smoke near 6000 rpms they said it was condensation or it could be from no cats but what is that?
and bTW the graph gets a little choppier at high rpms not real bad though. I have brand new ignition from opti to plugs. Any thoughts?
Old Aug 15, 2003 | 01:20 PM
GREGG 97Z's Avatar
Did you do the hotcam with stock rockers or with 1.6 roller rockers? I assume stock since you don't mention any. Also are those dual cat headers or single cat?
Old Aug 15, 2003 | 01:28 PM
they were stock rockers, and also the ehaders are eddelbrock shorty dual cat headers. thanks
Old Aug 15, 2003 | 01:48 PM
madwolf's Avatar
That is pretty rich, especially compared to the 14.8 you posted the other day. I would think there might be something else wrong because the tune you have is lean enough to get you in the high 12s. Can you send me the new AFR sheet?
Old Aug 15, 2003 | 01:52 PM
GREGG 97Z's Avatar
I was wondering about the rockers because most of the spec's listed for the hotcam include 1.6 rr's. With d/c headers and your mods and without 1.6 rr's your #'s don't look too bad to me.
Old Aug 15, 2003 | 02:45 PM
Re: NEW DYNO NUMBERS with LT4 hot cam. check it out!!!!!!!
Originally posted by TexasTechTA
....... Also the tempo was about 100 degrees and also I am such a moron my AC was going. .
Your results should be shown as "SAE Corrected".... this eliminates the effect of temperature, humidity, barometer and altitude. Doesn't correct for a hot motor or parasitic drag though...
Old Aug 15, 2003 | 03:01 PM
madwolf I will send you the AF sheet shouldn't there be about 20 more horses in it with perfect aF/
also i have eddelbrock headers, and no the numbers were not corrected I believe. I thought they were pretty good # despite the rich aF.
Old Aug 15, 2003 | 03:03 PM
ew AFR sheet?
The only thing that I did between the 2 dynos was replace all ignition pieces a new fuel filter and a new mass air stock.
Old Aug 15, 2003 | 06:15 PM
ttt
Old Aug 15, 2003 | 06:39 PM
If you get your A/F ratio into the high 12s you should get another 12-15rwhp. Don't go beyond 13:1
Old Aug 15, 2003 | 06:57 PM
blwnengineering's Avatar
i believe the perfect a/f ratio is 12.5 to 1, if your looking for the perfect mixture.
David
Old Aug 15, 2003 | 07:22 PM
FastZinTennessee's Avatar
Get the A/F thing sorted out and you should be very happy with the results. I think those numbers are pretty good for still running the stock rockers.
John
Old Aug 15, 2003 | 08:09 PM
93formula's Avatar
yeah nyou should get some 1.6 rr and you will notice a difference.
