Locations for temperature gauges
Old Aug 13, 2003 | 09:00 PM
kevmor99's Avatar
Is there any other areas for a temperature gauge beside the driver's side head near the front (stock location for gauge), the passenger's side head near rear (stock is plugged), or in the waterpump?
Old Aug 13, 2003 | 09:09 PM
funina91ss's Avatar
I put my temp guage in the LT head had to take out the sending unit to the car and left it off. You could get a "T" for it but I have long tubes and it looks tight and I dont need both of them.
Old Aug 14, 2003 | 12:45 PM
I needed an extra coolant temp sensor, so I added a brass tee in the line from the back of the heads to the radiator. See photo:
Temp sensor in coolant line
Old Aug 14, 2003 | 01:20 PM
JohnD's Avatar
You could put a dual sensor (from a later model Chev.) in the water pump which frees up the hole in the head for a sensor. BTW, you see the temps fluctuate a lot more when the gauge reads the temp in the head. My gauge reads the water in the pump, same as the computer sees and it never goes over 214. When it was in the head temps regularly passed 225 before the fans would switch on.
Old Aug 14, 2003 | 03:05 PM
kevmor99's Avatar
Isn't the temperature in the head more realistic though? In my LT1 swap I don't need the sender for the original gauge, I want to use the gauge for my truck, but it's capillary tube is too short and doesn't reach any further than near the rear of the engine.
Old Aug 15, 2003 | 12:52 PM
JohnD's Avatar
For the average driver, I think the block temp best represents what is going on. tha being said, for a drag race situation, I think the head temp is most important which wi probably what Chevrolet had in mind all along.
Biggiebound
Apr 21, 2015 11:28 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
