Part Number Help....
Old Aug 12, 2003 | 01:26 PM
rollin93's Avatar
I am looking for part numbers for the rubber trim at the top ofo the drivers door. This is the piece that "seals" the outside of the door and window. It also has rubber bumpers on the inside to help guide the window.
I am also looking for the part number for the channel that the window sits on. This channel connects to the up and down window tracks with nyloc wheels.
Both are for the drivers door. I went to a local dealer and looked up the parts, but he wouldn't hand over the part #..
Brian
Old Aug 12, 2003 | 01:33 PM
IXLR894Z28's Avatar
What year and make do you have?
Old Aug 12, 2003 | 04:09 PM
rollin93's Avatar
Genuis as work here....I guess that would help....'93 TA
Old Aug 12, 2003 | 05:16 PM
CamaroBoy96Z28's Avatar
I only have the parts manual for the 93-02 Camaro seeing that I have one. BUT I would assume the weatherstripping is the same.
So try these p/n's RH 10262724 LH 10302596. Thats for hardtop.
T-top p/n LH 10286717 RH 10429541.
I'm not sure which side the RH and LH are referring to, so I gave both of them to you. That is only for the weatherstriping along the top part of the door that seals in the window when its up fully. I'll try and find the p/n for the window channel too. Thats the best I can do though HTH.
Old Aug 12, 2003 | 05:38 PM
I don't think he wants the whole door weatherstrip from what he described.
If you want the outside strip on the top of the door, you want
10284223 LH
16625875 for the long channel at the bottom of the LH window.
Old Aug 14, 2003 | 10:17 AM
rollin93's Avatar
Thanks shoebox and camaroboy. Shoebox you are correct and those are the exact parts I was looking for....Thanks again, Brian
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
